Old 07-10-2012, 08:28 PM   #1
auxmike
auxmike's Avatar
Question A/T Fluid color changes over time
In the attached pic you will see;
2003 Tacoma, 54k, DEXTRON fluid
2008 yaris , 52k, WS fluid
2006 Corolla, 32k, Type T-IV fluid
They all have different color tones and all say on the dipstick no need to change.
Just wondering if my Yaris oil looks ok, it's kinda purplish....
Old 07-10-2012, 09:09 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
How did you get some of the fluid out? Did you just open the fill port and get it from there?
Old 07-10-2012, 09:48 PM   #3
auxmike
auxmike's Avatar
LOL! No, I just wiped off the dipstick of each vehicle ...
Remember, the A/T s have dipsticks and are filled via the dipstick tube.
Old 07-10-2012, 10:08 PM   #4
Lux
Lux's Avatar
Drives: NCP91
The correct method of testing ATF is to smell it and feel it between your fingers. Worn out fluid will smell burned and exhibit a grainy texture to it, like very, very fine sand. Discolouration is only the chemical breakdown process of the fluid dye and is not always a suitable indication of fluid condition. For instance, Hyundai ATF looks like diarrhoea at 15'000 km but smells, feels, and functions perfectly fine...
Major contributing factors to ATF service intervals are load (towing), driving aggression, and operating temperature (such as from a dysfunctional ATF cooler).
Lux is offline   Reply With Quote
Old 07-10-2012, 10:11 PM   #5
auxmike
auxmike's Avatar
Hmm, I think I'll try feeling for grainyness tomorrow. Thanks for the tip!
Old 07-12-2012, 02:09 PM   #6
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Toyota's WS trans fluid is rated at 280 deg for 30 minutes. It doesn't break down, instead you'll find particles suspended in the fluid.
I would think that the reason for changing the fluid is to get the fine particles out of the transmission.
The new WS fluid may smell burnt and that may be because of the way it's processed.
Old 07-15-2012, 09:28 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Yes, Toyota pretends its transmission fluid doesn't need to be changed, but that is a fantasy. 60k though is a minimum, depending on how aggressive you drive.
Colin Chapman disciple
Old 07-17-2012, 01:10 AM   #8
The Limo
Toyota Canada recommends that the A/T fluid be changed every 96,000 Km (60,000 miles).
Roy
The Limo is offline   Reply With Quote
Hang Time: Exploiting ECU Fuel Maps for Fuel Efficiency BailOut Fuel Economy Forum 20 11-13-2013 08:11 AM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
"Klunk!" One Time Noise When Backing Up jmharn General Yaris / Vitz Discussion 45 11-24-2008 03:43 PM
long time lurker, first time poster tekmoe New YARIS Purchase Forum 1 10-04-2006 12:43 AM
