Old 06-10-2012, 01:21 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
difficulty putting on the NST Alternator Pulley?!?!!
I'm trying to finally put the alternator pulley in and I'm having problems getting it done. I finally removed the alternator after having to get a swiveling long arm ratchet to get the bottom bolt off, but now I'm trying to figure out how to get the pulley off of the Alternator. the bolt is 22mm and the shaft has a 10mm 6pt head on it. Anyone know of a trick to actually get it off? Once i finally get the torque on it it slips and I would prefer not to round off the shaft head(that is what slips right now.
Old 06-10-2012, 08:40 PM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I had to put the pulley in my vise the first time.
-Type 07 FFL-
My odometer 03/11
Old 06-10-2012, 11:28 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
^ helped a guy using thw same method and then he replaced the OEM bolt with a new grade 8.
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 10:23 PM
NST (NonStopTuning) Short Shift Kit Info, Specs, User Data... NonStopTuning Performance Modifications 195 12-23-2011 12:44 AM
NST Sponsored Dyno Day In Houston NonStopTuning NonStopTuning 24 10-05-2009 02:26 PM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
-- 2008 NST HOLIDAY RAFFLE -- NonStopTuning NonStopTuning 50 01-28-2009 02:08 PM
