Old 02-28-2007, 05:34 PM   #1
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Space in the trunk???
How much space do you all think there is between the flip up spare tire hider and the actual spare tire. Reason I'm asking it that the bottom side of that fold up piece would be a great place to mount amps.....
Just looked...I figure there is about 30" long by 12" deep and 2" down at the tightest point...looks like I found my amp mount local.
jdubau55 is offline   Reply With Quote
Old 02-28-2007, 06:49 PM   #2
St_G
Drives: Black 2007 Yaris Liftback 1.5
2" of depth would be an "almost, but not quite" situation for most amps, wouldn't it? Assuming it/they would fit in places that didn't touch that tightest point, would there be some concerns over heat in such tight quarters?
St_G is offline   Reply With Quote
Old 02-28-2007, 06:54 PM   #3
jdubau55
Well my measuments are not exact but more of an eyeball guess. With the left tote tray removed there is plenty of room. As far as heat goes, a vent fan could easily be placed in the handle cutout to help keep the air moving. This would also help defrost your rear window in the winter ;)
Old 03-02-2007, 06:36 PM   #4
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
theres lots of room for an amp / amps under that tray. Im planning to move my battery back there and its like 7" tall. Just realised your probably asking what it is WITH the spare in the back correct? No reason for me to have a 14" spare anymore.
mikeukrainetz is offline   Reply With Quote
Old 03-02-2007, 08:04 PM   #5
jdubau55
Originally Posted by echo_hrs View Post
I've got a removeable amp rack mounted between my spare and the deckboard...The amp rack is angled down into the spare tire rim...So I have my spare still available and my amp...
Cheers
Cheers
I will prolly install with industrial velcro on the bottom of the decklid. IF I do need to get to my spare tire I dont want to have to remove my amp or anything. Of course that requires me to quit being lazy and install my amp so I can hook up my sub. I am bent on using my stock deck or swapping in my other mp3 cd player.
Old 03-04-2007, 11:05 PM   #6
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
I was going to do the same thing. Then, I looked closer and realized that the trays also act as supports for the spare tire cover. So I just put the amp "loose" beside the spare tire.
When I have time, I want to try something like echo_hrs' setup.
earljail is offline   Reply With Quote
trunk sub pix! drell42 In Car Entertainment + Electronics (audio / video / alarm) 21 07-26-2009 09:25 PM
Electronic Trunk Release Problem jonr0613 DIY / Maintenance / Service 5 09-08-2007 06:13 AM
Trunk issue Lowfront In Car Entertainment + Electronics (audio / video / alarm) 1 09-24-2006 06:55 PM
Enough Space? soros151 Performance Modifications 24 07-21-2006 02:43 AM
