Old 08-09-2015, 07:14 AM   #1
nehal.hasnain
Drives: Toyota Vitz 2009
195/60/R15 or 205/60/R15 : Help me to Decide for 2009 SCP-90 Hatchback Yaris/Vitz
Hi,
I am driving a 2009 hatchback vitz/yaris (SPC-90) with stock suspensions and wheels (with 185/60/R15 tyre) over a year now. Now, I am planning to change the wheels & tires. My choice is :
Rim : 7x15
Tyre : 195/60/R15 or 205/60/R15
Can anyone please suggest me if this is a good choice of rims/tires if I stick with my stock suspension and don't use any lowering spring/coils ?
Will 195/205 be too wide for a small car like this ?
nehal.hasnain is offline   Reply With Quote
Old 08-09-2015, 07:23 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Go 205/55 instead of 205/60.
At 205/60, you are looking at your car being risen to almost an inch!!
Sent from my A0001 using Tapatalk
Old 08-09-2015, 07:51 AM   #3
nehal.hasnain
Thanks IllusionX. But my current tyre is 185/60. Howcome 205/60 will be rising my car if I use R15 in both 205/60 & 205/55 ?
Sorry if I sound a bit dumb. This is my first car and I am changing the tyre/rim for the first time.
Appreciate any suggestion :)
Sent from my GT-I9300I using Tapatalk
Old 08-09-2015, 09:08 AM   #4
In tire sizing the /60 represents sidewall height. This is not a fixed measurement, rather a ratio of tread width. Therefor, a wider tire with the same aspect ratio as a skinnier tire will have a greater overall diameter.
Old 08-09-2015, 09:19 AM   #5
nehal.hasnain
Okey. Now I understand. Thanks WeeYari.
Old 08-09-2015, 09:22 AM   #6
nehal.hasnain
Btw, do u gyys think my stock suspension and scp90 chasis will be able to handle 205/55/R15 properly ? The roads I use for daily work are pretty rough & have lots of bumps.
Old 08-09-2015, 11:40 AM   #7
nehal.hasnain
And also, moving from 185/60/15 to 195/60 or 205/55.. does it hav any impact on fuel consumption ?
Old 08-09-2015, 12:53 PM   #8
Suspension fine. The wider the tire, the heavier it is, with a wider contact patch affecting rolling resistance. Fuel economy takes a hit.
Old 08-10-2015, 08:28 AM   #9
nehal.hasnain
Thanks a lot :)
