Old 07-25-2013, 08:23 AM   #1
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
Just A Header?
Hey All, Just curious, any one on here just run a header and kept the rest of the stock?
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 07-25-2013, 09:28 AM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I had an intake and header before I put on my custom exhaust. The gains were noticeable and it was quite a bit louder as well.
****edit***
the intake came well before the header so the noticeability of the gains were from the header.
Old 09-13-2013, 10:41 PM   #3
Echo86
Drives: 2003 Toyota Echo
What brand of header did you use for your car? Would it fit onto an Echo or did they change the Yaris a lot from the Echo?
Echo86 is offline   Reply With Quote
Old 07-25-2013, 10:05 AM   #4
Header was also my second mod after an intake.
Old 07-25-2013, 03:31 PM   #5
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
I'm not saying its pointless - but usually you want to improve flow on both ends - not just one...intake or exhaust.
JustDidIt is offline   Reply With Quote
Old 07-25-2013, 04:37 PM   #6
Silver Streak
Thanks guys, I was just wondering as a stand alone mod how good it was. Seems like it wasn't a waste of time by what I'm hearing.
Trd Exhaust
Trd Rear Sway Bar
Old 07-25-2013, 07:45 PM   #7
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
A header was my very first mod...
...but not for long. It's a good place to start. As a stand alone mod, it adds some low end torque. I use the steep hill leading to my house as a reliable indicator as the grade is always the same and I drive it every day. The car noticeably climbed the hill easier with less throttle. With other mods, now it flies up the hill.
Mods are like potato chips... you can't eat just one.
Greg
Old 07-25-2013, 09:19 PM   #8
BEEF
BEEF's Avatar
Car modifications add to each other. If you just put on a header, you get a certain gain. If you just put on an intake, you get a certain gain. If you just put on an exhaust system (axle back or more) you get a certain gain....
If you do ALL of them, it is more than the numerical addition of the gains individually.
I did the weapon-R like tooter though I heat wraped mine (probably a waste but it was unique). I have heard that the weapon-R, Megans, and the DC sport are all about the same. I guess that is a point that could be argued. I chose the middle of the road as it wasn't the bottom but wasn't the top either. I think any of them are better than stock. Stock is really small.
Old 07-26-2013, 12:44 AM   #9
JohnnyMalice
Drives: 2007 Toyota Yaris 4 door sedan
Does the header screw with Smog in CA? I know they dont like CAI.
JohnnyMalice is offline   Reply With Quote
Old 07-26-2013, 03:22 AM   #10
yariseggvvti
Drives: Yaris Hatchieback
I have header and custom pipe with TRD muffler. I had been past smog with no problem. Having a header is not going gain any hp. The final things are have those parts work together and the right mixture. Just make it flows better and smoother. You will notice the sound when the VVTI is active. Its like bhaaaaaaaaaaa.
yariseggvvti is offline   Reply With Quote
Old 07-26-2013, 01:34 AM   #11
There are two parts to a smog test: visual inspection and there is an OBDII or sniff test.
If your smog guy will pass you on visual (header is pretty hard to see back there), you should pass the sniff test fine.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Ceramic wrapping a header leoseller7 DIY / Maintenance / Service 2 04-21-2013 07:39 PM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
