Old 09-30-2009, 12:08 AM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
Blinding blue indicator light
When driving the Yaris on dark nights the blue high beam indicator light is so bright that it becomes annoying. I thought I read some where that a resister can be added to reduce the intensity of the light. Has anyone had any success with a fix for this one?
Thanks, Birdman
birdman is offline   Reply With Quote
Old 09-30-2009, 12:22 AM   #2
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
i always half-ass the high beams so it doesnt come on, pretty much inbetween hi and lo it shines more aswell
Old 09-30-2009, 12:26 AM   #3
puetato89
puetato89's Avatar
Drives: 08 Yaris
i know, but it blinds when it is really dark out and it gets destracting
Old 09-30-2009, 12:33 AM   #4
puetato89
puetato89's Avatar
Drives: 08 Yaris
lol, ok maybe not blinds but still annoying,
Old 09-30-2009, 12:35 AM   #5
Astroman
Modded Moderator
Astroman's Avatar
I also find it VERY annoying. I'm about ready to put electrical tape over it
Old 09-30-2009, 12:37 AM   #6
puetato89
puetato89's Avatar
Drives: 08 Yaris
or just do what i do
Old 09-30-2009, 01:31 AM   #7
birdman
You're right,"blinding" is an exaggeration. When I do long late night commutes and my eyes are tiring the brightness of the blue light is annoying, For now I wad up a paper towel to cover it.
Old 09-30-2009, 02:25 AM   #8
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Some well-placed scotch tape to diffuse the light a bit?
The blue one
Old 09-30-2009, 02:27 AM   #9
birdman
The tape is an option but I'm hoping for an electrical fix. Thanks for the idea.
Old 09-30-2009, 04:11 AM   #10
MGargano
Drives: 2009 Yaris Hatchback
Upgrade your headlights to bi-xenon HIDs from Xenon-Vision. For some reason, the way the kits gets wired, it stops the hi-beam indicator from lighting up on the cluster even though the hi-beams work perfectly.
Old 09-30-2009, 04:21 AM   #11
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Just don't drive with hi-beams on in the first place. If that little blue light annoys you, just imagine how the driver in front of you feels
Old 09-30-2009, 06:24 AM   #12
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
LAWL, just get strong foglights
Its a Chao!!!
Old 09-30-2009, 10:06 AM   #13
In the picture below, you can see the BEAM LED (D559). You could change its current limit resistor (looks like R640 {which is currently a 202 ohm resistor}, following the trace) to a higher value. Or, a much easier approach is mechanically reduce its output. My standard method for toning down overly bright LEDs on things is to simply dab the LED's lens with a black Sharpie marker. You can also use a think piece of gray or semi opaque plastic.
Old 09-30-2009, 10:11 AM   #14
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
i really dislike blue LED indicator lights that show up on everything these days, it truly is annoying, and the blue itself is way too bright; as for the dashboard, i think it makes sense to have one as you don't want to be driving around with your brights on all night-- that's not fair to others, so you should be reminded that it is on; even if it's a tad annoying. so to sum up, I bring nothing productive to the OP, hah :D
you could always crack open the dash and just replace the LED, or add a piece of painters tape onto the front for long drives
Old 09-30-2009, 10:45 AM   #15
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Thanks, Birdman
get a black electric tape and tape over it you wont even notice the tape..
Old 09-30-2009, 01:45 PM   #16
bronsin
bronsin's Avatar
Yeah if you can get at the circuit board masking the LED itself is the way to go.
Old 09-30-2009, 02:06 PM   #17
supmet
Drives: 2007 4 Door Yaris
There have been studies that show blue light creates more eye strain than any other color, but as others have pointed out, its a function, not a side effect.
Old 09-30-2009, 03:22 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
My '71 ford had a red light for the high beam. Much nicer.
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-06-2009 11:59 PM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 04:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 03:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 07:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 07:09 PM
