![]() Drives: Yaris Verso 1.3 2000 automatic Join Date: Nov 2015
Radiator fan doesn't start when the engine gets hot
Hi,
Here are the symptoms: - red temperature warning light starts flashing after some time, usually in city traffic - when the above occurs the radiator fan does not spin - the fan spins when I engage AC (even when the engine is cold) I exchanged FAN N.01 relay switch with HORN relay switch to see if the horn works and it does. When I remove the FAN N.01 relay and connect two pins with a wire as marked in the picture below, the fan starts spinning. relay.png |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 08:53 AM |
