![]() Drives: 08 Yaris 3DR HB AT Join Date: Oct 2012
Door "swing" on opening question.
Hello,
I have a 08 HB 3Dr and had a question on the door opening, either passenger or driver. Now, most other cars I've been in, or my other Toyota (FJ) have a "halfway" stop point and then a fully extended one. Is this true on the Yaris or am I missing anything? It just seems to fully extend and I don't want to hit/ding cars next to me. (Is there a part shared from another Toyota that I can add?) Thanks in advance! |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
The check strap (black flat metal piece in door jamb about midway) has two points on it. Half and full open. You can make sure its not loose by snugging up (not overtightening) the two bolts on the body side of it. Should be 10 mm bolts. I can tell you the length of the doors on the 3door hatch are longer than a sedan or 5door so you justhave to be careful as their travel to half open is farther than the others.
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... Last edited by Shroomster; 10-18-2012 at 11:20 AM. |
Thank you!
I will check when wifey gets home. |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
can someone take a pic of the bolts?
ok, so the yaris actually has one bolt on the body side:
![]() and two bolts on the door side:
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... Last edited by Shroomster; 10-18-2012 at 11:37 AM. |
Drives: Yaris Join Date: Oct 2012
On my 09 Yaris these visible parts are OK but driver's door opens all the way without stoping. So I think something is broken inside the door. Can anybody tell what parts are broken so I can buy them before disassembling the door? Or it is something that could be fixed without new parts.
Thanks |
#7 | |
| Help my doors are not opening | manuel_Ga20 | General Yaris / Vitz Discussion | 35 | 03-18-2011 12:52 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Question opening hours | IllusionX | New England | 4 | 06-09-2009 10:24 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
