![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
Smelly AC on windshield defrost.
Hey Guys, I seem to have a nasty smell coming out of my vents intermittently when my windshield defroster is on. If I switch it to windshield then turn the heat up it smells bad for a little while. It's a pretty sharp chemical smell. It doesn't last very long.
The a/c seems to work fine, the fan works on all settings and modes, I can't seem to figure out if anything is the problem. I just installed a new stereo, but I can't figure out how I could have screwed up anything doing that. I checked the AC section of the FSM and I didn't really go near anything important there. Does the AC come on automatically when the defroster is turned on in the Yaris? TIA for any ideas! |
If you do some searching on here for "smell" you will find a ton of threads about the AC stink issue. The AC does come on automatically with the defog mode.
Like Scott said, there's lots of threads about this issue, and even a couple of fixes. I tried one and it worked great.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
I did try searching first, but AC Smell didn't find anything.Then I used google and found the threads.
Read through the posts. Read through the TSB. Blew out the house and it was clear, stuck a cablie tie up into the ac and it was bone dry. No backup of messy water thankfully. ![]() Cabin air filter is pretty dirty, I'm going to change it out. Last edited by jayeh; 11-22-2012 at 10:24 AM. |
| Air not blowing out on windshield, will not defrost. | little_lulu3 | DIY / Maintenance / Service | 1 | 01-04-2012 12:34 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
| Avoiding Defrost setting for long periods of time | GeneW | Fuel Economy Forum | 1 | 12-24-2008 01:42 AM |
| Windshield Treatment Problem | Yaris Newbie | Wash, Wax, Detailing, Exterior Repairs | 20 | 12-12-2008 01:43 AM |
| chip in windshield | deebrown | General Yaris / Vitz Discussion | 0 | 04-04-2007 12:58 AM |
