Old 11-20-2012, 01:56 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Megan Coilover Install and Tips
Hey all,
hopefully this will be beneficial to those out there wanting to install these coilovers. The directions from Megan are a joke..Please note I take no responsibility for this install and don't claim to be a professional.. This is not a step by step diy, just simply showing you how the megans are assembled.
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 11-20-2012, 01:59 PM   #2
DeathBeard
DeathBeard's Avatar
#1- This is the most useful tool in my box, it's a craftsman offset box wrench, 17mm on one side and 19 on the other..This will save you alot of time on having to remove the windshield wiper assembly, simply bypass all the drama..
Proverbs 16:9
Old 11-20-2012, 02:01 PM   #3
DeathBeard
DeathBeard's Avatar
#2- I got these from ebay, they support the car without messing up the pinch welds, was sick of using hockey pucks, worth every penny.
Proverbs 16:9
Old 11-20-2012, 02:02 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I have created a DIY and Garm made a tip thread on MI
It is not super in depth but should be a lot more helpful
http://www.microimageonline.com/foru...ion-amp-Brakes
http://www.microimageonline.com/foru...er-Install-DIY
Old 11-20-2012, 02:07 PM   #5
DeathBeard
DeathBeard's Avatar
#3-There are already plenty of other useful threads on how to take the struts out, I am assuming you have already done this..The following photos show how to assemble the megans..I found that the strut bearing does not fit in the megan supplied red piece, so I just put over it, I ended up using ALL of the OEM pieces..
Proverbs 16:9
Old 11-20-2012, 02:10 PM   #6
DeathBeard
DeathBeard's Avatar
#4- When you reinstall the front on any mcpherson car you MUST LOAD THE SUSPENSION before you tighten the bolts. You can see that before tightenting the 19mm bolts the suspension is loaded
Proverbs 16:9
Old 11-20-2012, 02:12 PM   #7
DeathBeard
DeathBeard's Avatar
#5- Here is a comparison of the Toyota OEM camber bolt on top vs the stock on the bottom..These are so awesome and superior in every way to the ingalls spc type
Proverbs 16:9
Old 11-20-2012, 02:14 PM   #8
DeathBeard
DeathBeard's Avatar
#6--Front is done and moving to the back..Like others have mentioned the rear Megan spring is simply not low enough, I will be removing the spring perches.. Before
Proverbs 16:9
Old 11-20-2012, 02:17 PM   #9
DeathBeard
DeathBeard's Avatar
#7--And after! No more Megan spring perches and MUCH lower..I lowered the shock by 1" securing the spring in place.. I have no finger gap and the top of the tire is slightly tucked now
Proverbs 16:9
Old 11-20-2012, 02:19 PM   #10
DeathBeard
DeathBeard's Avatar
Enjoy your coilovers
Proverbs 16:9
Old 11-20-2012, 02:20 PM   #11
DeathBeard
DeathBeard's Avatar
I just drove it around the block and the springs have settled rear tires are fully tucked..and my rear end scrapes like a mofo on my driveway
Proverbs 16:9
Old 11-20-2012, 02:27 PM   #12
1.5
Form>Function
1.5's Avatar
Nice you got way lower than I could on the sedan. Great write up, way better than mine lol
Old 11-20-2012, 02:43 PM   #13
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You mean aftermarket on bottom, right?
Old 11-20-2012, 02:45 PM   #14
DeathBeard
DeathBeard's Avatar
as in the top is Toyota oem camber bolt and the bottom is toyota oem standard bolt
Proverbs 16:9
Old 11-20-2012, 02:59 PM   #15
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks! Weird, I'd thought the bottom would be the better one since it looks more robust.
Old 11-20-2012, 03:44 PM   #16
DeathBeard
DeathBeard's Avatar
it has to be skinnier to acheive negative camber
Proverbs 16:9
Old 11-20-2012, 05:05 PM   #17
1.5
Form>Function
1.5's Avatar
The size difference creates the camber I believe because it angles the spindle.
I had no idea Toyota made camber bolts. I have ingalls.
Firefox/Chrome Tips for Better YW Browsing tk-421 Off-topic / Other Cars / Everything else Discussions 13 11-26-2021 07:42 AM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Install Tips shambala9er Cosmetic Modifications (Exterior/Interior) 1 06-10-2009 10:01 PM
Install Help Please! beeheartsyou In Car Entertainment + Electronics (audio / video / alarm) 4 03-02-2009 11:29 AM
Remote start Valet 561r install AlexNet0 DIY / Maintenance / Service 17 12-29-2008 11:00 PM
