Old 12-04-2017, 07:07 AM   #1
rabbito
rabbito's Avatar
N/A build completed....
okay so this is it...i really wanted to fully mod NA and see how far it goes(without internal polish etc)..it doesnt matter how slow it is, i wanted to see the maximum potential of 1nz..yes i would have made 60whp+ on honda engine with this set up but yeah....
it was a fu*ken b*tch to get and connect brake booster and evp vacuum hoses...
- k&n pod intake to tb..spacer and intake manifold..hoping this gives out at least 10whp...that intake pod sound is really annoying lol..i am going to compare from my last dyno result...
- crank and pcv delete (no law)
- lightweight pulley...rpm speed increased with this set up..around 500rpm faster..
- 320cc injector E85 with piggyback ecu control unit & 272 9.5 cams (without valve/springs) set to 7,300rpm...this was probably the biggest hp i gained....this set up gave me about 15~20whp
- grounding wire with battery safe unit
- header....probably get 2 or 3 hp out of this setup...haha...
my afr reading lean..cars slow af right now..its like going than suddenly cars going lean...lol....i will update tomorrow with retune/dyno
Sent from my SM-J730GM using Tapatalk
Cosmetic: Toyota red emblem
Budget 1nzfe build (n/a) nuclear90 Performance Modifications 5 12-10-2014 05:17 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
N/A Build !! Gabwone Tracking, Racing, Auto-X Forum 18 10-23-2014 05:12 PM
Warranty Information for US Yaris Owners AdeJong 03 General Yaris / Vitz Discussion 4 09-19-2009 10:14 PM
