![]() ![]() ![]() Join Date: Sep 2014
DRL fuse..
I saw the right fuse box on the motor compartiment...
If i install the right fuse (7.5amp) can i use the DRL system? Wich cables i need to tap ... See picture |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
Um, no?
I assume only one of the fuse holder's side has contacts :D Retrofitting things that go deep like this into the wiring is a pain in the ass.
I drive, therefore I am. |
The DRL relay goes on the left of the radio. If your car didn't come with it, it appears that you cannot just buy the relay to plug it in.
| power outlet/cigarette lighter fuse location | Idahotom | General Yaris / Vitz Discussion | 1 | 01-08-2014 05:45 PM |
| Blown or missing gauge fuse causes strange symptoms on a 2007 Yaris hatchback | vandallen | DIY / Maintenance / Service | 1 | 06-06-2013 09:59 PM |
| 30A Power Fuse Instrument Panel Location? | Kioshi | DIY / Maintenance / Service | 16 | 03-31-2013 06:53 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
