Old 02-06-2013, 06:13 PM   #1
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Blackout section between upper and lower grilles, opinions.
I want some opinions before I actually do this. I like the look but I'm just not sure. Take a look at my quick photoshop and tell me what you think.
Captain Slow is offline   Reply With Quote
Old 02-06-2013, 06:17 PM   #2
Captain Slow
and with yellow fog lenses for good measure
Old 02-25-2013, 10:50 PM   #3
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
I have always been impressed by your little detail upgrades over time.
Killchain is offline   Reply With Quote
Old 02-06-2013, 08:26 PM   #4
Klink10
Klink10's Avatar
If the lower grill was just a bit narrower...maybe. As you have it laid out....not a fan.
Old 02-06-2013, 08:41 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
personally, I dont like the look. the grills don't match up enough to make it "flow". But its your car. If you like you, you should rock it!
-Derrick-
Old 02-06-2013, 10:02 PM   #6
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
this is an old picture of mine, which ive redone since then but the bottom grill i left the same. personally i love the way it looks and Id recommend it. i used plastidip but it took a couple tries to get it right, especially at the upper grill because of how it curves.
you could use plastidip too adn if you end up hating it peel it right up! just remember to pull the tape before each coat dries and re-tape. its a pain but its the only way to get a clean line.
like this but i changed it since then so the curve at the upper grill doesnt look so awkward.
lol okay
Old 02-06-2013, 10:55 PM   #7
Captain Slow
can you repost the pictures? they're not showing up. thanks!
Old 02-06-2013, 11:35 PM   #8
catliektheif
Drives: 2010 5 Door
try this thread
http://www.microimageonline.com/foru...ight=plastidip
are you a member on MI?
lol okay
Old 02-25-2013, 08:34 PM   #9
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by catliektheif View Post
try this thread
Yours looks effing great!
It's because the black follows your vertical hood lines.
2012's don't got 'em.
Old 02-26-2013, 01:15 AM   #10
catliektheif
Drives: 2010 5 Door
thanks!!
lol okay
Old 02-25-2013, 06:44 PM   #11
Sparcoboy
Drives: 2008 XP9 by Sparco
Did you try it out?
thinking of doing the same on my red '08 LB. 08 should make easier lines I guess since the top grille is wider.
Sparcoboy is offline   Reply With Quote
Old 02-25-2013, 08:31 PM   #12
tooter
play every day
tooter's Avatar
Capt... we're thinking along the same lines.
I was also considering the same idea, but my vents also have slanted edges even worse than yours and it doesn't look right if they're not vertical. That's one of my biggest laments on the 2012's, that they don't have rectangular vents.
Pics of upper & lower grill mods + more minired5stby Cosmetic Modifications (Exterior/Interior) 33 10-28-2012 03:32 PM
Painting plastic mesh? Upper and/or lower. wholenizz Cosmetic Modifications (Exterior/Interior) 2 05-20-2010 08:22 AM
In need of upper and lower grilles and upper grille cover bam2626 Items for Sale by private party 2 06-25-2009 10:34 PM
