Old 02-17-2013, 02:16 PM   #1
Yarflana
Drives: 2008 Base Model
Decision to lower more?
Ok, here are pics of my ride right now with Eibach Pro springs and Tokico reds on full hard running 16x7 rims and 205/50/16 Kumho tires.
I have a sense that the Tokico reds on almost full hard keep the springs from compressing as much as they would if the struts/shocks were on a softer setting, but I am not sure they would drop much more so I need to try a much softer setting and see if the "stance" is lower or not.
Right now, the space from top of the tire to the edge of the wheel well on front and rear is 1.5"...I would like more like 1/2" inch total.
If setting the struts/shocks on a softer setting will not lower it much more, then what springs would you suggest I need front and ear seeing the current setup in these pics to put the fenders about 1/2 inch above the tire? Tanabe DF210s?
Thanks for any suggestions.
Yarflana is offline   Reply With Quote
Old 02-17-2013, 04:02 PM   #2
UberSilver
UberSilver's Avatar
I think it looks great! I would not lower any more.
And the shocks have no effect on ride height.
Old 02-18-2013, 03:47 AM   #3
yariseggvvti
Drives: Yaris Hatchieback
I got Tein basis coilover. I lower the front about inch an half and I could lower half inch more to close the gap between fender and tire. The rear I lower it just touch the rear fender. I will post some pictures soon.
If you want to adjust the height, you should go for coilover.
yariseggvvti is offline   Reply With Quote
Old 02-18-2013, 09:28 AM   #4
Yarflana
Can you adjust your height and dampening with your coilover?
Old 02-18-2013, 10:45 AM   #5
^ Tein street basis is height only, not damping. Megan/Cusco/H&R/etc. allow damping adjustment also.
Old 03-08-2013, 12:40 PM   #6
Yarflana
Ok I have decided to lower more. Anyone with springs suggestion? I am not getting coilovers at this time so just springs suggestions please.
My goal is to close the front and rear gaps to approx. 1/2 inch each. Right now they are about 1 1/2 inch.
Old 03-08-2013, 01:15 PM   #7
Next "level" of drop is:
MI springs
Tanabe DF210
Tein S Tech
Eibach Sportlines
Old 03-08-2013, 01:33 PM   #8
Yarflana
Garm, thanks. So if I need about 1" more drop, evenly, which would do it at the lowest cost. You already know I can adjust dampening with the Tok reds.
Old 03-08-2013, 01:34 PM   #9
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I've been struggling with the decision to lower more for a while also. Been running NF210s but I'd like to see the car lower. I just worry about scrubbing.
Old 03-08-2013, 01:39 PM   #10
Yarflana
I am not concerned about lowering more because I can just stiffen the Tok reds to the point they don't allow any spring compression of any significance.
Now, I would drive more than a day like that because everything else has to absorb the road changes.
I think if I have 1/2" wheel gap, I can continue to stiffen the ride till rubbing is very minimal.
Lower than 1/2" and my front will easily rub as the fender is right at the tire edge; rear, I could lower more, but I like them with almost the exact same wheel gap and is a sign of thinking about it vs just throwing on some springs.
Old 03-08-2013, 01:57 PM   #11
with your HTS reds, and at the best price point, you cannot beat our MI branded springs.
Old 03-11-2013, 02:33 PM   #12
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Leave your car alone! Screw looking bad ass and having your car slammed down to the ground. The ride fricken sucks, and you have to drive your car like you are scared of every dip and bump in the road.Why all of that just to look hard?My biggest mistake was getting coilovers; I never could be happy with one setting. Either the ride is too high,too low,too stiff, or never right period. You have a good set up. Those springs and shocks alone are just about the same price as a set of ok coilovers. Your car may not look as shocking as one that is slammed or hellaflush, but I bet its more fun to drive.
marlondog is offline   Reply With Quote
Old 03-11-2013, 02:47 PM   #13
Yarflana
Hey, I do really appreciate the honest thoughts.
I have thought of this and this is why I do not plan to slam it. I am happy with some wheel gap, but I know that I can have a comfortable ride and still drop another inch.
As well, if I were in a town, or had a regular drive schedule over bad roads and rough territory, I wouldn't do it. Additionally, I am keeping the stock springs, most likely, and could go back anytime if things just didn't work out.
Now...those that go for the "penny-off-the-ground" frame drop, that is way too much for me and they are welcome to it and I agree it cannot be very comfortable.
So, I have elected to go with DF210's to keep the drop even and another 1/2 to inch.
Old 03-12-2013, 08:27 PM   #14
atxsteve1
Drives: THE RED HATCHY
I have a set of slightly used teins I can sell you.
atxsteve1 is offline   Reply With Quote
Old 03-12-2013, 10:50 PM   #15
Yarflana
Thanks but DF210s are here tomorrow and on the car on Saturday. We'll see how it works out.
Thanks,
Old 03-12-2013, 10:54 PM   #16
atxsteve1
Just let me know I'm not too far away.
Old 03-13-2013, 11:37 AM   #17
I think the DF210's are a bit firmer than the Teins, and the Teins go just a bit lower and are a little softer. More or less comparable, really. That's been my experience after a few installs.
Old 03-13-2013, 11:55 AM   #18
atxsteve1
Yeah they drop close to 2 inches front and back and are pretty comfortable ride.
I was running 18x7.5s 45mm offset with 215/35/18s lol and those springs with no rub.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Want to lower 1" or so. hmmm piranha0522 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-25-2011 03:59 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
