Old 03-20-2013, 02:13 PM   #1
Biukyuu
Drives: Yaris 09 LB 5 dr
215/40/r16 rubbing ?
I currently have yokohama s-drives in front this size and there is no rubbing as i am not dropped at all.. I wonder whether there will be rubbing in the back if i have the same size tires.
my mags are 7" wide with offset 38.
p.s My car is completly stock . I am also wondering whether itll be bad for the engine or gears.
Thanks
Biukyuu is offline   Reply With Quote
Old 03-20-2013, 02:26 PM   #2
justjesus
justjesus's Avatar
Drives: 2008 Liftback
I was lowered on Micro Image springs and ran same size tire (but i think mine was 45 series), on similar sized wheel.
only rubbed in front during really hard cornering
The rear only rubbed on the freeway (bumpy portions) with 3 passengers weighing a total of 675 lbs or so.
here's a link to how they looked on the Yaris
http://yarisworld.com/forums/showthread.php?t=30668
Old 03-20-2013, 04:25 PM   #3
justjesus
justjesus's Avatar
^ the offset is either a + or - number (zero offset not included)
Breaking this down as easy as possible, I'd describe it as:
- gives you more outside lip. the higher the number, the more lip
+ gives you less lip.
Back in the old days, "deep dish" wheels had that huge amount of lip. Those were - with really high numbers.
I like to go to this website for comparing wheel and tire sizes (as well as offsets). I use it often.
http://rimsntires.com/specs.jsp
Old 03-20-2013, 05:05 PM   #4
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
here is something I found on a google search I assume that when we say an offset of 40, we mean a positive offset of 40..or 38... or whatever.
so bigger positive number means more tucked tires...I think.
Old 03-20-2013, 11:00 PM   #5
Biukyuu
my offset is negative 38 i had forgot to clarify that.
so i guess the rear wheel will never rub unless i change my rubber to more then 40's right ?
rubbing
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
Rubbing botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-06-2009 03:32 PM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 05:09 PM
