Old 03-28-2013, 10:58 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Question about the TMPS
how do i change them out?
do I have to take them out from the inside of the tires?
I assume that i can just change them over from one tire to the other with no problems, and that which wheel they come from doesn't matter because they trigger at when any tire pressure gets down to around 28 psi.
Old 03-29-2013, 06:25 AM   #2
You have to remove the tire to change it. If you move them from one set of wheels to another, it doesn't matter which goes where, as the Yaris TPMS doesn't keep track of tire position.
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
Side mirror compatibility question kw531 DIY / Maintenance / Service 3 12-11-2009 10:09 AM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
