Old 02-04-2013, 11:54 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Rear wheel speed sensors
I've been following the rear speed sensor issue with the last gen Yaris and was wondering if anyone with a 3rd gen has taken a look at the plug on the rear wheels to see if they're still using the same crappy connector? If so, it might be a good bit of preventative maintenance to take the connector apart now while it's still new and see if they've added dielectric grease to it. If not, add it to ensure they never fail from the get go.
Old 02-05-2013, 01:39 AM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
are u talkin about
that plug?
Old 02-05-2013, 02:51 AM   #3
mr_miles
Drives: 2013 Yaris
That's a speed sensor? I was wondering what that was then I put my hub spacers. delicious -3 degrees.
Old 02-05-2013, 04:40 AM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
i thought it was an abs sensor.
Old 02-05-2013, 10:09 AM   #5
Bluevitz-rs
Yes that's the sensor. Call it what you will, I'd pack a little bit of dielectric grease in there to prevent it from corroding if it still the same sensor.
Old 04-11-2013, 11:42 AM   #6
kanaga
Drives: '08 yaris sedan
kanaga
I'm in the process of replacing my rear abs sensor. I have already removed the hub assembly and replaced the sensor. When re-attaching the hub assembly, should I use lock-tite on the bolts?
kanaga is offline   Reply With Quote
Old 04-11-2013, 11:43 AM   #7
Bluevitz-rs
Was there any on the ones you removed? I think you just need to torque them to spec.
Old 04-11-2013, 12:45 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
If there wasn't any loctite on it before it isnt nessisary but it dosnt hurt either.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
HELP - Removing rear hub! Doc Zaius DIY / Maintenance / Service 16 05-13-2009 03:52 PM
