| View Poll Results: Engine oil type | |||
| Full synthetic |
15 | 75.00% |
| Semi synthetic |
3 | 15.00% |
| Mineral oil |
2 | 10.00% |
| Other (please explain) |
0 | 0% |
| Multiple Choice Poll. Voters: 20. You may not vote on this poll | |||
![]() ![]() Drives: Yaris Join Date: Feb 2013
Engine oil type :semi,mineral or full
Guys, what type of Engine oil do you use in your car? Semi, full or mineral?
And if so, what is ur servicing interval (I know that toyota recommends 10km). I use semi synthetics shell helix. And do servicing at 8,000km interval. I am planning to move to full synthetic shell helix ultra soon and do servicing at same interval 8,000km...want the best for my engine...! But heard lots of things concerning leaks when using full synthetics... |
![]() ![]() ![]() Drives: 2008 lowered yaris on 17's Join Date: Feb 2015
Hey there! There is a forum dedicated to oils and I think you will find a lot of information (or should I say opinions) on oil. I have never seen a seen a complaint about engine leaks with our motors while tuning synthetics. I run royal purple full synthetic with the OEM or K&N oil filter. Trying to get the most lifetime out of my baby. Just ticked over to 99000 miles. Also I chasing my oil every 3-5 thousand miles.
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
Mobil 1 semi synthetic with 5000 mile change, OEM oil filter.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
Toyota Canada conventional (mineral oil) with 8000 Km change and Toyota Canada oil filter.
Roy |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Royal purple 10,000 or once a year, which ever comes first.
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Its a modern car so i use modern oils, oil of choice Mobil1 full synthetic changed at 10K kilometer intervals. Car has 200K and to date has only required regular maintenance.
Have Yaris will travel.. |
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
I have taken my Yaris to the dealership where I bought my car for every oil change since my purchase date in 2010, and they told me if you are punctual about your service intervals, there is no reason to use synthetic. Therefore, I always opt for conventional oil. I change my oil every 5,000 miles/6 months, just like the Owner's Manual dictates.
well, I am using semi-synthetic for 4 years already and I can say that when my odometer reach 5,000 miles (8,000 Km equivalent), my engine oil has darkened quite a lot... say; when I first service the car, the oil color is brownish transparent ... and at 5,000 miles it is moderate brown but not dark...
So obviously, mineral oil at 5,000 miles will be much worse and quite a stretch for the car... (?)! But it is interesting and impressive that many guys here still trust mineral oil's ability. I know there is a forum which has copy-pasted information from another site but which provides a lot of useful information : http://www.yarisworld.com/forums/showthread.php?t=40495 |
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
Mobil 1 5W30 Full synthetic here, because it makes me feel like a responsible car owner. The Yaris saves me that much in gas, I might as well treat it.
Note: I have no proof to show you that this oil does anything better for these cars. Right, service interval. 8000 km/ 6 months is reasonable to me. Any further and I feel bad for Yaris. Any shorter and it's wasting my time. General internet consensus (however credible that is) dictates that your oil change frequency affects your engine more than your choice of synth vs conventional. Regarding leaks.. Better to fix the leak, not change the oil to accommodate it? |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
Well here in Bay Area California, Go to any quick change oil place for 5w-30 oil (bulk) and you are going to get Semi-synthetic regardless of who's name is on the bulk tank. Most likely because of the high degree of reprocessed used motor oil going into the bulk supply system. In most cases its also an ILSAC GF-5 rated oil,. Which is good. But self certified I'm strongly considering switching to Eneos motor oil. Pricey but at least you know what you are getting what you paying for. Reuse, repurpose, recycle, It may be great oil, but who knows one batch to the next.
![]() ![]() Drives: 2010 Yaris Join Date: Jan 2010
Another Mobil 1 5W30 user. I use Extended Performance and change my oil once a year. Typically that's about 7000 to 8000 miles per year, my 5-1/2-year old Yaris has just under 40,000 miles.
I feel that I need a stout oil because the Yaris does a lot of short trips (less than 3 or 4 minutes) but it also does a few highway trips.
The moving power of mathematical invention is not reasoning but imagination. Augustus de Morgan Truth does not change because it is, or is not, believed by a majority of the people. Giordano Bruno |
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
My dealer uses the recommended Toyota Genuine Motor Oil 0W20 (U.K.). 1.33 litre petrol(gasoline) "Optimal Drive", whatever that is!
Service interval is 10,000miles/12 months whichever comes soonest. |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Oil Type and service manual | Jason Tabone | General Yaris / Vitz Discussion | 7 | 07-09-2012 04:48 AM |
| Changing Engine Oil (Mobil) | lijet | DIY / Maintenance / Service | 1 | 07-05-2012 03:01 PM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
