Old 05-04-2013, 07:14 PM   #1
rikk
rikk's Avatar
Drives: 2007 Yaris Hatch
Miata "M" seven spoke 14" wheels
Will these fit an 07 Yaris?
miata.net shows them as 14x6 4x100 with 45mm offset...
rikk is offline   Reply With Quote
Old 05-04-2013, 07:36 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's a very strong maybe. The biggest issue with smaller diameter wheels is the brake calipers. There are versions of the Yaris that ship with 14" wheels, and other members have successfully installed 14" wheels from other cars (myself included) with good results. There are even some people with 13x9 steelies, but those are racing wheels.
Old 05-04-2013, 07:41 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
You should be good to go with 14s, as the base model yaris comes with that. I think you're good to go until you go smaller than 14". Other members have run miata wheels just fine.
Old 05-04-2013, 07:49 PM   #4
rikk
rikk's Avatar
I'm a little concerned because I read the daisy wheels do not clear the calipers
but those are 5.5" wide according to miata.net
Old 05-04-2013, 07:51 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
I'm sure one of the wheel specialists can chime in to make sure. I bet one of 'em will chime in on the wheel in a bit
Old 05-04-2013, 08:34 PM   #6
rikk
rikk's Avatar
quick photoshop
Old 05-04-2013, 09:15 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
With a +45 offset you should be ok, but check the backspacing. Almost all Miata wheels will fit a Yaris, but after a certain year they changed the Miata, and some newer wheels do not fit.
Also, if you plan on modding the brakes at all then try something else. My 14" wheels clear the brake calipers by mm's.
Colin Chapman disciple
Old 05-06-2013, 09:27 AM   #8
Yaris1987
Drives: Yaris
Those will work fine
Yaris1987 is offline   Reply With Quote
Old 05-06-2013, 12:03 PM   #9
Wisher23
Drives: LB
Don't forget to check the hub bore size to see if its the same size as the yaris or bigger. If its smaller, the wheels won't fit without machining the bore wider.
Wisher23 is offline   Reply With Quote
Old 05-06-2013, 02:10 PM   #10
rikk
rikk's Avatar
how about 15" BBS wheels?
i dont know why i thought they were 14"
theyre 15"!!!!
Old 05-06-2013, 02:10 PM   #11
rikk
rikk's Avatar
12lb wheels!
Old 05-07-2013, 07:39 AM   #12
rikk
rikk's Avatar
54.1 bore is just like the yaris right?
Old 05-07-2013, 07:02 PM   #13
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Yes, they fit. Direct bolt on.
http://www.yarisworld.com/forums/showthread.php?t=37630
D&D is offline   Reply With Quote
FS: Mini Cooper 5 Spoke Wheels with Tires, Hubcentric Rings and Lug Nuts CTScott Items for Sale by private party 14 08-17-2012 11:18 PM
14" Miata wheels on Yari D&D Photo-Video-Media Gallery 7 12-20-2011 07:17 PM
FS: 16x6.5 miata wheels with 205-45-16 tires thebarber Items for Sale by private party 11 06-20-2010 11:20 AM
