Old 03-18-2007, 08:52 PM   #1
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
hard time installing fogs.
I bought the same thing as his.
http://www.yarisworld.com/forums/sho...ight=fog+light
I'm stuck at the part of putting the fog into the bumper.
Asking for a screw driver which wasn't included in my box so I'll use w/e I got, second is the wires..what path does it go to, and how does it go into the car, where's the hole to bring it in?
thx in advance..
-- Blen
Old 03-18-2007, 09:33 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
directions packed with the lamps?
Old 03-18-2007, 09:55 PM   #3
Blenjar
Blenjar's Avatar
Nope..
Took a while to get the plastic out of the fog light place..lol
If sumthin can take pictures of explain where the wiring goes and plugs into..that would be mighty fine.
-- Blen
Old 03-20-2007, 08:03 AM   #4
Blenjar
Blenjar's Avatar
can sum1 post pictures of where the wiring goes in the engine bay? it will give me an idea..ANYTHING THAT DEALS WITH FOGS post, to give me an idea of the routing and installation for the wiring.
THX IN ADVANCE
-- Blen
Old 03-20-2007, 08:43 AM   #5
punch
punch's Avatar
THX IN ADVANCE
-- Blen
the official fog light install is on this website in the manuals section, i'll let you search for it, the if you still need help email it to you...
punch is offline   Reply With Quote
Old 03-20-2007, 08:38 PM   #6
Blenjar
Blenjar's Avatar
can you email it to me? thx buddy
-- Blen
Old 03-27-2007, 06:37 PM   #7
Blenjar
Blenjar's Avatar
which side does the fog go in. The pkug should be facing up or down?
-- Blen
Old 03-27-2007, 11:55 PM   #8
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
white wire - to battery
red small wire with large grey plug to 12v swiched (I used the 12 volt acc plug) grey wire is 12v,
No predrilled hole into the engine bay use ac drain hose.
you will need extra wire 10 guage recomended.
You will need to extend red wire to the fogs it is to short.
lamp socket should face down
tiksman is offline   Reply With Quote
Old 03-28-2007, 06:28 AM   #9
Blenjar
Blenjar's Avatar
Where where you hunny!!?!
thank you so much.
-- Blen
Old 03-28-2007, 10:24 PM   #10
Blenjar
Blenjar's Avatar
So the only way without driling hole is to use the AC/coolant hole>? squiz it there? the toyota guy said its not recommend but what do you think? nobig deal rite?
-- Blen
Old 03-28-2007, 11:07 PM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
There is a rubber plugged hole directly above the computer mounted on the firewall. Put a rubber gromet in it's place and you have your hole.
Old 03-28-2007, 11:35 PM   #12
Blenjar
Blenjar's Avatar
Can you like take a picture of that?
Thx in advance..
-- Blen
Old 03-29-2007, 02:17 AM   #13
Speedz
Will work for Yaris...
Speedz's Avatar
Drives: Yaris
You can see it just behind the battery if ur car is a LH model...
its circular in shape... not hard to find...
Speedz is offline   Reply With Quote
Old 03-29-2007, 08:17 AM   #14
tiksman
tiksman's Avatar
I never seen a rubber plug on mine. I drilled another hole sinec I have a amp wire also.I used a firewall rubber groment I found at a salvage yard
long time lurker, first time poster tekmoe New YARIS Purchase Forum 1 10-04-2006 12:43 AM
Hard time choosing color; dark colored cars absorb more heat?? fantabulousbaby New YARIS Purchase Forum 21 08-07-2006 07:53 PM
