Old 11-04-2013, 09:43 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
0 offset
0 offset on 07 hb with sportline springs...can i run it with 195 45 15 ...any pics with this set up ...will i have problems ?
Old 11-04-2013, 10:13 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
width of rim?
Old 11-04-2013, 10:42 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
width of rim?
they are 15x8 0 offset
Old 11-04-2013, 11:45 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You will have problems.
Old 11-05-2013, 05:59 AM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I normally start here: http://rimsntires.com/specs.jsp
That at least gives you general recommendations for fit and clearance, as well as a general idea of relative size.
Old 11-05-2013, 07:09 AM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
How much fender work are you willing to do and how much camber are you willing to run?
Im running 16x10 +20-23 in the rear which pokes ~5mm more than a 15x8 +0 but I rolled and pulled my fenders and am running about -6 degrees of camber.
Read this thread I posted a few years ago
http://www.yarisworld.com/forums/sho...&highlight=end
Old 11-05-2013, 10:36 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
ty ..for ur answers , what im looking for is a set up that will have my wheels just in the wheel wheels...dont like the flash look plus thinking of going lower with coilovers ..stock is 45 offset so anything around 37 to 40 should do it on a 7 inch rim not sure on tire size tho..
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
Please confirm this fit (185/60R 15 on 15x6.5 +38mm offset) Dave55 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 03-03-2012 06:36 PM
Questioning the Recommended Tyre Widths based on Offset Energiser Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-24-2012 10:32 AM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
