Old 08-23-2013, 09:13 AM   #1
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
Want fog light projectors
Hey all
As the title states, I'm looking to potential upgrade my fog light fittings on a third gen Yaris to projectors. Any out there that are recommended?
I'm using my fogs as DRLs at the moment and I like that clear light output you get from projectors.
Thanks in advance!
The forever growing to do / to buy list:
FIX Projectors - FINALLY DONE!
XB LED fogs - Done
Lowering springs - Done
MOMO Revenge Evo X - Currently selling body parts for
Declare bankruptcy - Done
Eren_13 is offline   Reply With Quote
Old 08-23-2013, 12:35 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Garm use to have them listed in his store but I cant find them anymore. Shoot him an email and see if he has any left over or can order a set
Old 08-26-2013, 07:04 PM   #3
Eren_13
Eren_13's Avatar
Thanks for the reply. Will go ahead and send over an email. Are they a straight replacement for the yaris then? And while its mentioned, anyone got any photos of them installed?
XB LED fogs - Done
Old 08-26-2013, 07:09 PM   #4
We had projector foglights for the sedan, but I'm not sure if we did for the liftback. I'll have to look back through the orders to see.
Old 08-27-2013, 10:43 AM   #5
1.5
Form>Function
1.5's Avatar
Oh I didnt know they were different
Old 08-30-2013, 08:30 AM   #6
Eren_13
Eren_13's Avatar
Thank you! It is lift back I'm after. I've mentioned previously but it's for the 3rd gen as well.
XB LED fogs - Done
Old 08-30-2013, 01:28 PM   #7
I haven't seen any projector fogs for the 3rd gen liftback. Always looking though.
Old 09-10-2013, 08:37 AM   #8
Eren_13
Eren_13's Avatar
Thank you :) please let us know if you do find something!
XB LED fogs - Done
Old 09-14-2013, 12:21 PM   #9
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
after my wife takes delivery of her yaris i will be doing some measureing to see if i can get these to work, these also are ready to be wired up as high beams. they look sweet!
https://www.theretrofitsource.com/pr...ducts_id=18725
Old 09-20-2013, 08:06 PM   #10
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Do a retrofit....I did. Since the Mini H1 Headlight Retro Fit went so well. Was considering the projector fogs.
Some photos taken from here:FOG COMPARISON :: Hella, Blazer, Bosch, OEM Reflector
But wasn't happy with the beam pattern as fog lights... but they make a GREAT driving light with a GREAT cut off...but no foreground for fog light use...but after seeing the light pattern from the Hella Micro De Fog Light - pretty sure this is what I'll use:
Comparison of the light pattern - Blazer has awesome cutoff but barely any foreground:
I'll like mount them in the yellow lens housing foglights to keep the look I already have:
Retro fitting - Kinda like this - using a circle cutter or dremel to round out the back housing to mount the Hellas in the OEM fog light - thus retaining mounting points and aiming capability. I will be using a H3 3000k HID 55W setup with this.
(FYI...the above fog lights aren't mind or the oem 3" fog lights - this image was pulled from a Tacoma retrofit using 4" fog lights.)
JustDidIt is offline   Reply With Quote
Old 09-20-2013, 08:08 PM   #11
JustDidIt
JustDidIt's Avatar
So the lights came in...
But the OEM housing is a PITA to cut open...must be die-cast aluminum.
Old 09-20-2013, 08:13 PM   #12
JustDidIt
JustDidIt's Avatar
...and Finished!
Hella Micro De mounted with JBWELD to OEM cast aluminum fog light
Broke the glass lens while trying to separate the glass from the housing, ended up getting some .25" glass cut to 3.5" circles then coated them with 3 coats of Dupli-color Metalcast Yellow from TCPGlobal and 2 coats of clear spray paint to get the yellow lens look I wanted. Then resealed the lens with a waterproof silicone. You can see that the paint isn't 100% clear but doesn't stop the 3000k HID bulbs much. The good thing about doing the paint this way, I can remove the yellow paint at anytime in case I want to change the color of the bulb or lens and no longer have yellow fog lights but a 5000k driving light.
H3 3000k HID bulb held in by (6) washers
Because of the new length and size of fog light the bumper mounts for the oem bulb had to modifed and resized as well as a hole had to be opened behind the headlight for the length and the back of the HID bulb wires. This is a picture of roughly what was done with a dremel.
OEM ---------------------------------------------------------Modified
Installed
Just need the adjust the aiming...will have that done hopefully this wknd.
Old 09-20-2013, 10:18 PM   #13
yarisgeo13
yarisgeo13
Drives: gloss black 5 door
Send a message via Yahoo to yarisgeo13
Nice addition on the lights.
yarisgeo13 is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 05:27 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
