Old 10-28-2008, 11:06 PM   #1
billk
Drives: 2008 Yaris Sedan
Seat belt buzzer is silenced
I seen this thread on the before hack days. But don't see it now.
I was really annoyed by that stupid seat belt buzzer when I take off my seat belt. I wear it all the time, but pulling into my neighborhood, or parking lots, I would release my belt. Then came the Buzz from He&&. I went to my dealer to get my free oil change,( I get free oil changes for a year) and I asked my service guy if the mechanic can disable that darn thing. He said, sure not a problem. I left the dealer with my seat belt off, went up to 55 mph and no buzzer. Light still blinks, but silence.
I seen in the old discussion how someone went into the console and nuked the buzzer. Or how a dealer said it was not a changeable option. In the owner manual, it even says the buzzer can be disabled.
I am happy now, no buzz, buzz, and more buzz.
So if this is posted elsewhere, buzz me and move it.
bill K
2008 yaris sedan
only 1 mod, nuked the buzzer
billk is offline   Reply With Quote
Old 10-28-2008, 11:24 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Dude!
Please let me know how your dealer did this... Mine refuses to do so, on the grounds that disabling the buzzer might disable the whole airbag assy (stupid, I know).
Welcome to the forums!
Old 10-28-2008, 11:39 PM   #3
billk
The mechanic hooked up his laptop to the yaris, went thru the menu and disabled it. In the owners manual in the back, there is something about customizing the buzzer sound option. This will not disable the airbag or anything else. Your Dealer is pulling your leg.
b K
Old 10-28-2008, 11:49 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Well, I know it can be disabled (some members have done it in the past), but those guys at my dealer don't seem to know which code to punch or something...
It would be awesome if you could figure out the steps involved (through your dealer) so that I can let those boneheads know.
Old 10-29-2008, 03:32 AM   #5
*MAD DOG*
*MAD DOG*'s Avatar
From what I understand of the situation is that the seat belts have a pre tensioner in them to help stop whip lash. These pre tensioners are linked to the airbag control system. In the event of a crash the pre tensioner in the seat belt and the air bags deploy.
Old 10-29-2008, 12:11 PM   #6
b_hickman11
Drives: 08 Sedan
This has nothing to do with the buzzer......
Old 10-29-2008, 10:04 PM   #7
briman
Drives: 2008 Toyota Yaris, automatic
Great thread.
I hate the seatbelt alarm. My dealership won't shut it of. I've even contacted corporate about the manual and they said they changed their policy for US owners. I won't buy another car from that dealership or any dealership that won't do what I ask to my car. Safety my ass. There's no law requiring an alarm.
briman is offline   Reply With Quote
Old 10-30-2008, 09:46 AM   #8
MUSKOKA800
MUSKOKA800's Avatar
I just wear mine so have no issue with that sound.
Old 10-30-2008, 01:48 PM   #9
itracs5
Drives: 2007 yaris sedan
buzzer on 07 sedan
Fyi, I could not stand the buzzer anymore so I decided to shut it up, heres how to do it easily. remove the snap in trim around the cluster and radio. unscrew the cluster, 2 screws, unplug the 2 harnesses attached to the cluster. when it's free turn it upside down and carefully remove the back cover, a couple screws and some plastic snaps hold it on. When you remove that cover you will see a small round black module (buzzer) with a hole in it, carefully pull or pry it up, it is plugged in to the board with two prongs, once it is removed replace the cover, reinstall the cluster and harnesses and enjoy the quiet. No adverse effects at all.
itracs5 is offline   Reply With Quote
Old 10-31-2008, 02:13 PM   #10
dybbuk
dybbuk's Avatar
Drives: 2008 Yaris HB
Except that you lose all alarm buzzes right? I sometimes leave my keys in the car or the lights on and bad things would happen if I lost that alarm altogether
dybbuk is offline   Reply With Quote
Old 10-31-2008, 03:35 PM   #11
nemelek
DWEED
nemelek's Avatar
I had the dealer do it after threating the salesman with a bad review. At first they said it couldn't be done but then I showed then a page from http://www.etimago.com/yaris/repairmanual/ Meter section page 11. There are 4Customize Parameters that can be changed using their intellegent tester. One of which is the seat belt buzzer. This helps when my old fat dog rides shotgun.
Old 11-03-2008, 07:40 PM   #12
dybbuk
dybbuk's Avatar
You sir. Are a genius!
Old 11-10-2008, 03:29 PM   #13
Snappy
Drives: 2 Yaris Hatchbacks
Is it totally silent, or does it buzz when you first start the car and drive off, then goes totally silent?
Snappy is offline   Reply With Quote
Old 11-10-2008, 05:37 PM   #14
nemelek
DWEED
nemelek's Avatar
It beeps 5 times than is quiet. There is no noise if you take off while the car is running.
Old 11-20-2008, 09:39 PM   #15
Tiddlygoose
Tiddlygoose's Avatar
Drives: 2009 Honda Civic Sedan SI
I wonder if I hook up the Code scanner from Autozone if it will allow me to change that setting myself? My Dealer refuses to disable it as well. A$$hats!
Tiddlygoose is offline   Reply With Quote
Old 11-20-2008, 09:45 PM   #16
No - You need the Techstream scantool and software.
Old 11-21-2008, 04:21 AM   #17
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The beeper doent really bother me as i use the seatbelts but if i was going to disable the buzzer isnt there a sensor under the seat? and wouldnt unplugging it disable the buzzer?
Old 11-21-2008, 10:47 AM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That would also disable the whole airbag assembly, since you would be disabling the seat pressure sensors. Not a good idea.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Drivers Side Seat Belt Won't Retract redyaris DIY / Maintenance / Service 8 08-07-2014 10:37 AM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 01:34 AM
