Old 02-15-2021, 06:23 PM   #1
futuredenied
Drives: 2007 yaris s
2009 hatch Longer front strut options
I have a 2009 yaris hatch. This is my 4th yaris. I've also owned 3 prius's and one prius C. Great cars. I'm looking to increase the ride height buy 2-3 inches total. I read what CTScott did with crashy, and another member did close to the same by lengthening the strut. I could make this work except use the bottom strut hole for the top knuckle bolt and build a bracket for the bottom knuckle bolt. That appears to be around 2.25 inches and would work. I'd rather just buy a 2 inch longer strut if one is available? I know I'll have to lenghthen the sway bar links and I have the rear covered. Thanks
futuredenied is offline   Reply With Quote
Old 03-06-2021, 01:01 PM   #2
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Sorry, can't help with longer strut options. I'd say your best bet would be a bone yard. Remove a yaris strut and look around for others that would fit the bill having the yaris strut to compare.
Good luck and don't forget to share if you find anything!
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-22-2007 11:08 AM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 06:53 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 02:26 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM General Yaris / Vitz Discussion 3 08-30-2006 09:43 PM
