![]() ![]() Drives: 08 hatchback Join Date: Jun 2011
Hybrid conversions for performance!!!
Are there any possible hybrid conversions to make more performance. Is it possible to add a prius hybrid system and tweak/ program it to combine the power from the gas engine about 100 hp and the two permanent magnet AC synchronous motors producing 60 kilowatts and 80 horsepower for a total of 180 hp??
If there is a shop that does that let me know I would be interested how much? Read more: http://www.ehow.com/facts_7906583_el...#ixzz2stgLz2id http://www.caranddriver.com/news/toy...-and-info-news Or like a hybrid r style conversion with two electric motors in the rear to make it 4 wheel drive with this company http://www.evdrive.com/products/evd-motor-controller/ |
Very interesting, expensive project. I'm not sure how you're going to re-engineer a hybrid system though. Swapping in a 3rd gen Prius' 1.8L hybrid powertrain would be an idea.
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Or a Tesla set up.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
![]() ![]() Drives: Vitz S 2007 LB Join Date: Feb 2013
Crazy idea but i really hope it works... be careful of black smokes rising from your hair thou, lol
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Probably cheaper and easier to just buy a Prius C ;)
![]() ![]() ![]() Drives: No more Yaris Join Date: Dec 2013
Yup.
The idea...got me thinking...what would be the advantage of a Prius setup in a Yaris body. I really can't see it. Is the styling that important? I remember two Jeep projects I was involved in. First, twenty years ago, someone had a rusted-out Jeepster Commando. That was Jeep's prototype SUV/CUV of the 1960s. Small station-wagon body on a stretched Jeep CJ chassis. Back then, fiberglass replacement Jeep bodies were available by several makers. This guy, bought a CJ-6 tub to mount on his frame. The CJ-6 was a rare bird; from 1956 to 1975 they only sold about 20,000 of them. Most of them to various government agencies. Worked until they were scrap. But, with plenty of grief, he did get that body to fit. The frame was mostly the same but the axles, spring mounts, body mounts, steering column, pedal setups...all very different. But he wanted his CJ-6, and eventually he got one. About ten years after that, I got myself a Jeep YJ Wrangler. I, too, wanted a CJ - and hanging a CJ front clip on the YJ looked like a fifteen-bolt project. So, with a lot of work, I found the parts - and then with WEEKS of trimming, fitting, more trimming, more fitting swearing, painting, shimming...I had my fake CJ-7. And of course the first thing the Jeep purists would ask me was: "WHY? Why does the STYLE matter?" It did, to me, at the time - I liked the retro look, more utilitarian than the styled erzatz Jeep look of the original Wrangler. But those were LIGHT modifications. Here you're going to take an INCREDIBLY complex system, out of the car it's been designed for, and put it into a much-smaller car it was not. Just the thought of that work gives me the willies. And what you get out of it...is, literally, a Prius with a differently-styled body. Hey, everyone to his taste. If you like the idea and want it that badly, go for it. But I think long before you even reach the halfway point, just buying a Prius will seem like a much better idea. |
you be better off adding a electric motor in place of the power steering pump location and a xB or Echo two belt pulley. Then add your batteries and a controller.
#9 | |
http://en.wikipedia.org/wiki/Toyota_...Specifications |
Ok but it's still makes less power than just the 1.5 on its own. So again, not much of a PERFORMANCE upgrade.
Still seems to be much less work to get the 1.5 four banger back up to 106 hp, or drop in the 1.8 from a Matrix.
#12 | |
![]() ![]() Quote:
If you knew how the hybrid synergy drive system worked, you'd know that 180hp will never happen. MG1 is your main propulsion unit. It's basically what propels the car. MG2 is cupeled to the engine and is mostly a generator. There's a bunch of planetary gears in there and depending on what direction MG2 spins and ICE speed determines your forward speed. It's not a simple system like honda uses, by just adding an electric motor to the system. It's very complex.
#14 |
It's just an Idea I'm not an engineer, would be cool to see it implemented.
#15 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
I still think this is the best option...
420hp - Done! ![]() http://cleantechnica.com/2013/09/10/...ally-revealed/ |
#16 |
Thats sick the motor.
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| 2013 Ford Fusion | Kal-El | Off-topic / Other Cars / Everything else Discussions | 13 | 09-08-2012 07:08 AM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| 2011 Toyota Yaris Hybrid | tuckevalastin | General Yaris / Vitz Discussion | 48 | 03-30-2009 07:42 AM |
| Yaris Spanks Hybrids in Environmentally Friendliness in Dust to Dust report | nsmitchell | General Yaris / Vitz Discussion | 45 | 05-08-2007 10:33 AM |
