Old 03-27-2014, 10:58 AM   #1
esse10
Drives: 2009 yaris 2 door
TPMS
Anybody have the part number for the yaris TPMS rebuild kit?
The *&&*+ at my local dealer was not very cooperative in giving out part numbers.
esse10 is offline   Reply With Quote
Old 03-27-2014, 11:27 AM   #2
The third gen kit is: 04423-33030
One per wheel is required.
Old 03-27-2014, 12:04 PM   #3
esse10
hhmm?
hmm , now you got me thinking ctscott. how do I know what generation I got on my 2009 yaris 2 door hatchback, base model?
Old 03-27-2014, 12:07 PM   #4
Sorry - You are second Gen. There was another post about TPMS this morning and that one was 3rd gen related.
04423-33030 is correct as well for 2nd gen.
Old 03-27-2014, 12:09 PM   #5
esse10
cool
Well alright ........you are a SUPER TROOPER MY FRIEND
Many thanks
Julian
Old 03-28-2014, 08:25 AM   #6
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
You can always just bypass the thing and just put in regular valve stems in your wheels... a whole lot cheaper.
Old 03-29-2014, 01:06 AM   #7
frambach
Drives: 2008 Liftback
Won't you have a constant light on in the dash if you go the rubber valve stems route though?
frambach is offline   Reply With Quote
Old 03-29-2014, 08:00 AM   #8
For 06-11 Yaris you can do my TPMS bypass to keep the light off (and optionally do it with a switch so when you swap back to rims with sensors they will still work). For 3rd gen Yaris this will not work though, as the 3rd gen ones send the messages from the TPMS system to the cluster by CAN bus message.
www.yarisworld.com/forums/showthread.php?t=11058
Old 03-29-2014, 04:52 PM   #9
esse10
TPMS DIY bypass
I Saw that diy on bypassing the tpms and definitely in my future TODO list.
fyi- the part number for the rebuild kit from Toyota has changed to; 044230-E010 for those folks still looking to find the kit online or something.
Old 04-02-2014, 05:28 PM   #10
frambach
Is there a difference in TPMS & TPWS?
Is that just different auto manufacturers saying the same thing?
I understand the two acronyms. Just wondering if the actual systems are different.
Old 04-02-2014, 05:54 PM   #11
warning vs monitoring.
Ours is really a warning system, as you can not actively see the info on the tires. Monitoring systems typically have the ability to display the pressure in each tire.
Old 04-02-2014, 06:09 PM   #12
frambach
That's sort of what I was figuring. We aren't actually monitoring the tire pressure as much as getting a light when something is out-of-whack.
Thanks for the reply.
I've bookmarked your TPWS bypass DIY. If I keep these Miata wheels on (and our valve stems from the steelies can't be installed into them) I'll have to look into getting that light off in the dash.
TPMS questions NEexpat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-02-2013 06:18 PM
any tpms swaps out there? steel to aluminum? severous01 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-26-2011 08:10 PM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 09:11 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 10:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 01:18 AM
