Old 03-14-2014, 08:15 AM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Exclamation Cold Engine
I have had this problem for about 8 months now. My cool engine light stays on no matter how long I drive. No CEL or anything related to it. My Scan gauge shows that the max temp it gets while cruising is 118F. If I am stuck in bad traffic and its a standstill, then it will rise to about 140F and the light goes off. When I get some speed it returns to 118F and cool light comes back on.
So my question is what would cause an engine to stay running cool even after an hour of highway driving?
Things I will be replacing are the Coolant temp sensor and the thermostat. That's all i can think of.
Old 03-14-2014, 08:27 AM   #2
Most likely it is just that the coolant temp sensor is bad.
Old 03-14-2014, 08:48 AM   #3
bronsin
bronsin's Avatar
wouldn't that mess up the carburation?
Old 03-14-2014, 09:10 AM   #4
It would make the car run a bit rich, but if you keep driving with it that way the fuel trims will adjust it out.
Old 03-14-2014, 09:11 AM   #5
Yoda
Yoda's Avatar
I am think so too CT. Easy to replace I will start there first. Maybe that's why its running so rough when its cold out.
Old 03-14-2014, 09:40 AM   #6
bronsin
bronsin's Avatar
a yup.
Old 03-15-2014, 06:49 PM   #7
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Could it be thermostat stuck open? Is heater working OK or too cold?
jack black is offline   Reply With Quote
Old 03-19-2014, 07:18 AM   #8
Yoda
Yoda's Avatar
Heater is working fine but sometimes when the AC is on cold, it fluctuates between warm and cold.
Getting the temp sensor today to see if that works.
Old 03-20-2014, 08:22 AM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I'm voting bad thermostate.
Old 03-24-2014, 08:46 AM   #10
Em_
Drives: 2007 Yaris
It's pretty dabgerous because if the fan ever needs to start and it doesnt you can damage your engine
Em_ is offline   Reply With Quote
Old 03-24-2014, 08:57 AM   #11
Yoda
Yoda's Avatar
Have not had the time yet to do it. I will try for this weekend and let you guys know.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
1ND-TV engine swap Daox Fuel Economy Forum 11 10-01-2015 02:49 PM
Car engine/hood cleaned boggydee Wash, Wax, Detailing, Exterior Repairs 8 10-19-2010 02:47 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
