Old 04-30-2014, 05:57 PM   #1
digitalprecinct
Drives: Vitz 2009
Post DIY, can i install HID which have High and low beam together in Vitz 2009?
Hello,
I purchased this HID and I have been told that I can install in Vitz 2009, but i noticed that in my original headlight high beam and low beam is separate bulbs, and the one i purchased is in one bulb. I want to know is it possible that I can install this in Vitz 2009. Photos are attached.
any kind of help will be appreciated.
Thank you in advance.
digitalprecinct is offline   Reply With Quote
Old 04-30-2014, 07:32 PM   #2
Do you have a picture of the headlight on your 09 Vitz? The OEM HID headlights on the Vitz RS have an HID low beam bulb and a separate halogen high beam bulb, but the non-RS Vitz just have one bulb with a high and low filament.
Old 05-01-2014, 03:15 AM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
if your low and hi beam are seperate...then that hid kit you have wont even plug in to anywhere..you need to get D4R bulbs.
Old 05-01-2014, 12:42 PM   #4
digitalprecinct
Drives: Vitz 2009
Hello everyone, here is my original light. If i only change the bulb can i use the same hid blaster? Or the whole kit need to be replaced?
Old 05-01-2014, 05:22 PM   #5
digitalprecinct
Drives: Vitz 2009
Post
Here are the photos of my headlight, if i change the bulb the same kit will work or i have to change the kit also?IMG_0559.JPG
Old 05-01-2014, 05:49 PM   #6
Originally Posted by digitalprecinct View Post
Here are the photos of my headlight, if i change the bulb the same kit will work or i have to change the kit also?Attachment 53429
Attachment 53430
You have the HID headlight with the halogen high beam. To use the kit you would have to make some wiring changes to bypass your existing ballast.
Since you already have HIDs, why do you want to change to the kit?
Old 05-01-2014, 06:14 PM   #7
digitalprecinct
Drives: Vitz 2009
Hello CTScott,
I do not have any knowledge about this stuff, I even didnt knew it that I already have HID :D
I have been told that if i get this HID kit, i will have much brighter light and i purchased it.
do you think that with this 55w HID ballast kit i will have more light? if yes, i can do the wire changes if you guide me.
Thank you in advance for your help.
Old 05-01-2014, 07:26 PM   #8
Hello CTScott,
I think it will be identical to what you have now, as I believe that the Toyota 90981-20009 HID bulb is a 55W bulb as well. Also, the aftermarket ballast with your kit will not be 1/2 as reliable as the OEM Toyota ballast.
If you still want to do the conversion, I recommend getting a set of non-HID headlights and using those with the kit. You could then sell those OEM HID headlights for a significant price.
Old 05-01-2014, 11:55 PM   #9
enviri
enviri's Avatar
Drives: 2010 Yaris
sell it to scott :P wait...is turkey driving on the same side as US? i think it does...
Old 05-02-2014, 12:02 AM   #10
He's got a Vitz, so they must be RHD headlights?
Old 05-02-2014, 12:04 AM   #11
enviri
enviri's Avatar
Drives: 2010 Yaris
but it could be those french built ones, and there are a few LHD countries!
Old 05-02-2014, 12:11 AM   #12
But then it would be a Yaris, rather than a Vitz.
Old 05-02-2014, 09:26 AM   #13
IllusionX
Drives: 07 Yaris Sedan Aero
Most of Europe are LHD.
Old 05-02-2014, 09:32 AM   #14
Yes. But, if he actually has a Vitz it will have been imported from Japan, rather then being a European Yaris. That is pretty common in some areas over there (like Malta for instance).
Old 05-02-2014, 06:47 PM   #15
jcboy
Drives: Sedan 07
Correct. as what they do in NZ and Australia.
Even in the philippines where they are/need to be converted to LHD but still referred to as their original (JDM) names (vitz (yaris), fit (jazz), etc.) since the local (PhDM) versions are called their local names.
diy, hid, high beam, low beam, vitz 2009
DIY Low intensity high beam ? JudgeM DIY / Maintenance / Service 1 12-08-2013 09:01 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 10:49 AM
Does anyone know how to rewire a Low beam HID kit, for both LOW/HIGH beam use? Syroyizhka General Yaris / Vitz Discussion 1 11-30-2009 11:47 PM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 10:37 AM
