Drives: 2005 and 2006 scion xb Join Date: May 2015
tuning for turbo
hi everyone, i am new to this forum, but was directed here for additional help.
I have an 06 Scion Xb (same motor) and am working on throwing a turbo kit on it. its a greddy kit, with emanage blue PnP piggy back. ive heard the emanage is not the easiest software to use for tuning, but i am hoping it will get me by for now. Im running larger injectors, and will be monitoring the A/F wideband, but besides emanage, what do you all use to tune your vehicles? is AEM fic a better solution for piggy back? this thing isnt going to be insane or anything, and ill only be running 5psi boost. i just want to make sure its not leaning out under boost. any recommendations would be useful. also, i live just outside Chicago, so if anyone is from this area and knows how to use emanage, please feel free to contact me, as i may need some help soon. |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I'm currently running the blitz supercharger at 6 PSI with the AEM FIC and 1zz injectors and it's been doing great for me.
I also used the boomslang harness for the FIC just for the sake of plug and play ease. |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
is it a must with the blitz S/C kit to have timing control or does the stock ecu do a good job if you have some sort of fuel control already?
#4 | |
The blitz kit comes with it's own fuel controller that you wire into the ECU and has it's own maps. It's so that you can use the lo/med/hi/off feature of the blitz's clutch on the supercharger. Mine however had a bad clutch, so I decided to have it welded so it's always on and ditched the blitz fuel unit and used the AEM FIC. |
Mr. 155 and climbing
Not a lot of folks here that use the emanage. The rule of thumb is to use a piggyback that local shops will support if you are in a pinch or just down right want a professional to set up in general.
| Supercharged 2nz-fe VVTI tuning | iwanttobeamole | Forced Induction Forum | 2 | 09-02-2012 07:30 PM |
| 1NR-FE Performance & Tuning | nickstamat | Performance Modifications | 20 | 08-31-2010 05:02 AM |
| Smoky Nagata of Top Secret Japan brings his tuning talents to Houston! | Turbofc3c | Southwest | 2 | 02-19-2010 02:25 AM |
| Anyone need ECU tuning done on American Vehicles? | Nexus1155 | New England | 5 | 06-10-2009 07:15 PM |
| FS: Redline tuning Hood Lift | yrsdrgn | Items for Sale by private party | 9 | 11-03-2008 08:15 AM |
