Old 02-19-2013, 05:49 PM   #1
vten
1zz Tb on a blitz supercharger ... Any good ?
Reading the manifold thread , most ppl added the 1zz TB .... I was wondering If I should add the 1zz th for my fixed pulled blitz supercharger ....
Any thought ?
Thanks guys
Old 02-19-2013, 07:01 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey vten,
In my opinion, you'd have throttle response up the ass.
Even running non aspirated...
...I can cruise down the freeway at 65 with just my big toe resting on the gas pedal. Your forced induction could only multiply that advantage even more. The real question is... how big is the bore on your Blitz? a 1ZZ is 55mm.
Greg
Old 02-19-2013, 07:19 PM   #3
vten
I have no idea on the blitz bore .... But I'll find out :)
Old 02-19-2013, 08:21 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Good question. I don't know that it would make much of a difference in output (without a standalone ECU) but it would certainly improve pedal response.
Old 02-19-2013, 08:26 PM   #5
vten
Hmmm yeah ..... Since I have it tuned with the AEM FIC, do you think re-tune would be needed ?
Old 02-19-2013, 09:09 PM   #6
CrankyOldMan
That's tough to say. If you have an AFR gauge and it's showing lean at WOT, then I would recommend a re-tune.
Old 02-27-2013, 07:44 PM   #7
CrankyOldMan
Ok, having looked at the mating interface between the Blitz and the TB, I don't think that you would get much out of a 1ZZ throttle body. Reason being, the inlet on the Blitz is sized to the 1NZ, so you'd have a nasty step down in diameter and likely have issues holding the gasket in place. If you know someone with welding skills that could do a cast-to-plate joint, you could make your own adapter. Maybe.
Old 02-27-2013, 08:23 PM   #8
tooter
play every day
tooter's Avatar
Can you post a pic of your inlet, Cranky? What about simply grinding out the bore to a larger diameter? Then the only issue would be making a gasket for the 1ZZ throttle body. I had a 2mm step on mine and just took a Dremel to it to make it work by rounding off the sharp edge.
Old 02-27-2013, 08:34 PM   #9
CrankyOldMan
It looks pretty much identical to the one you posted, but with the 1NZ gasket channel.
Old 02-27-2013, 09:40 PM   #10
tooter
play every day
tooter's Avatar
Yes, it does...
The difference is that this one matches the 51mm bore of the 1ZZ manifold all the way through while the other one tapered out from the 46mm 1NZ bore to match the 51mm.
When Toyota went from the Corolla 3 bolt throttle body to the 4 bolt, they also increased the bore diameter from 51mm to 55mm, so there was a 2mm step around the edges which got smoothed out with a grinder.
Old 02-27-2013, 10:00 PM   #11
Astroman
Modded Moderator
Astroman's Avatar
I my 1zz TB. Just need a supercharger to go with it.
Old 02-28-2013, 12:34 PM   #12
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I'd be interested in this. It would be nice to have a better throttle response.
Old 03-03-2013, 07:21 PM   #13
CrankyOldMan
Finally spent some time with the Blitz, the 1ZZ throttle body corpse and a camera today.
My suspicions were confirmed: the intake flange is only sized for the 1NZ throttle body. There's an awful nasty step and potentially exposure of the gasket itself.
There isn't really room to modify the existing flange, because it's only about 1/2" thick.
The casting is also very thin, and not very smooth inside.
Old 03-03-2013, 07:30 PM   #14
47_MasoN_47
That's unfortunate.
Old 03-03-2013, 09:16 PM   #15
tooter
play every day
tooter's Avatar
Yeah, I had that same issue with the very first prototype adaptor.
You could still make an adaptor plate that smoothly reduces to the stock diameter. You already have the perfect pattern. It's on the bottom of your 1ZZ throttle body.
I'd just drill 4 slightly larger non threaded holes 60mm square in some aluminium plate and get some longer throttle body studs to hold everything together and use a stock O ring gasket under the adaptor. You could then make a stock diameter bore hole in the center of the adaptor to fit your supercharger, and then file or Dremel it to flare out to the larger 1ZZ diameter at the top. You'd need to cut out a flat gasket for the throttle body to get around needing to groove it for an O ring, but it wouldn't be all that difficult to do.
Remember, this isn't just the engine passively pulling in air. It's the supercharger pumping it in. And ok, so there will be a slightly higher manifold vacuum in front of the supercharger, it would still be the larger throttle body that's metering the air.
Old 03-04-2013, 06:36 AM   #16
CrankyOldMan
That would be the next logical step, but I was thinking from the "bolt-on" side of the garage. Not everyone has access to the facilities that we do. =)
A few alternatives (of varying feasibility) would be: buy a 50mm throttle body spacer and turn/grind the taper; scavenge the intake side of an xB kit and use the tooter TB flange; scavenge the intake side of an xB kit and make your own elbow/flange; learn to do lost-wax investment casting and make your own; etc. etc.
Last edited by CrankyOldMan; 03-04-2013 at 06:41 AM. Reason: changed from comma list to semicolons.
Old 03-04-2013, 09:15 AM   #17
47_MasoN_47
Thanks for that :) I don't have the tooling to do much more than open the box and bolt parts on. If it requires milling/lathing/etc. I'm just SOL.
Old 03-04-2013, 09:22 AM   #18
vten
If possible, cranky or tooter , are you guys mind to make the adapter from the blitz to the 1zz tb ?
BLITZ supercharger kits IN STOCK cali yaris Micro Image 34 06-02-2012 10:31 AM
FS: blitz supercharger kit + camcon vten Items for Sale by private party 20 02-22-2012 09:12 AM
Blitz supercharger and everything else. 56K beware camelll Items for Sale by private party 23 05-06-2011 09:32 AM
gap for spark plugs for the blitz supercharger? whooppee777 Forced Induction Forum 2 03-12-2011 01:09 PM
