Old 05-21-2013, 07:50 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Aftermarket steering wheel audio control??
Has anyone found anything that works with our car, got a new headunit, looking to get some audio controls mounted on steering wheel for better access, thanks
Old 05-21-2013, 09:59 PM   #2
Steve (Echo_hrs) bought a JDM Yaris steering wheel with the audio controls and connected it to his aftermarket radio using one of the PAC steering wheel control modules. If you don't have cruise control installed you have two extra wires in the clockspring that can be used. If you have cruise, a JDM or 3rd generation Yaris clockspring has the extra wires required to run both cruise and audio controls.
Old 05-21-2013, 10:11 PM   #3
caineroad
caineroad's Avatar
Is there anything out there that is just an aftermarket clip on thing?
3rd gen yaris, you mean 2012+?
Wasn't there is a thread somewhere that people tried to fit 2012 wheels into our yaris but no success?
Old 05-21-2013, 10:20 PM   #4
The clip on ones require the HU to support IR remote controls.
I am not sure about the 2012+ steering wheel fit on a 2nd gen Yaris, but I am almost positive that the clockspring would work.
Old 05-21-2013, 10:36 PM   #5
TOLMACH
Drives: soarer
Aftermarket HUs have remotes for steering wheels
Below is an example for pioneer hus
http://www.ebay.com/itm/Steering-Whe...39c0e5&vxp=mtr
Old 05-21-2013, 10:42 PM   #6
caineroad
caineroad's Avatar
this is the one I bought:
http://www.yarisworld.com/forums/showthread.php?t=28867
Old 05-21-2013, 10:44 PM   #7
That may be intended to work with the Toyota OEM steering wheel controls. Does the manual for it explain the pinout?
Old 05-21-2013, 10:50 PM   #8
caineroad
caineroad's Avatar
This is where I bought it and the information given
http://www.autodvdgps.com/car-dvd-gp...ies-p-565.html
Old 10-08-2014, 05:11 PM   #9
jcboy
Drives: Sedan 07
hi scott, i know this is an old thread. but after thorough searching online and in yw, I've come to conclude that if the clockspring connector below the column (white 10-pin/12-pin, the one beside the yellow one for the airbag) only has an X number of wires, then there are also X number of connections you can make with the connector to the steering wheel itself.
Example, if i have only 3 wires there, and since one of them is for the horn, i can only use the other 2 for steering wheel audio controls, bluetooth or cruise control.
Is this accurate? I mean, can we not "pin" the white connector below the column and also pin the connector on the steering wheel? in other words, does the clockspring ribbon have wires inside for this?
Old 10-08-2014, 06:12 PM   #10
That is correct - What you see for pins on the black connector is all that is run through the clockspring.
Old 10-08-2014, 07:14 PM   #11
jcboy
Drives: Sedan 07
Pft. Oh well goodbye steering wheel control project. Lol
Thanks scott!
Old 10-08-2014, 10:32 PM   #12
enviri
enviri's Avatar
Drives: 2010 Yaris
here's the connector on the JDM audio control for reference.
Old 11-20-2014, 10:27 PM   #13
ReedH
Drives: 2013 Toyota Yaris Hybrid
Keep in mind that the cruise control also goes through the clockspring. I keep planning to tap into that clock spring connector to design a clever way to use the cruise control arm as steering wheel controls when the cruise control is not in use but just haven't had the time.
ReedH is offline   Reply With Quote
Old 11-21-2014, 06:25 AM   #14
It would be easier to just use a clockspring from a Toyota that has cruise and audio controls. Otherwise you would have to add a microcontroller and a digital pot to intercept the signal and generate the completely different voltage drops for cruise versus audio controls.
Steering Wheel question heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 33 03-07-2012 01:27 AM
Steering Wheel Controls - Part 2! revolution Cosmetic Modifications (Exterior/Interior) 3 11-26-2010 02:53 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
audio volume control on steering wheel hans_fh In Car Entertainment + Electronics (audio / video / alarm) 18 01-04-2009 09:07 PM
