Old 07-21-2012, 12:35 AM   #1
richard_rsp
richard_rsp's Avatar
Drives: 2012 Yaris L 3Dr
MR-2 wheels and tire questions
Hey everybody! I picked up some pretty nice MR2 Spyder wheels today (unfortunately the tires are the wrong size, so I will be getting new ones, but that's ok, they were a great deal anyway)
As you may know, the MR2 wheels are 6" wide in the front and 6.5" wide in the back, so I will be running a staggered wheel set.
I am thinking I want to run the 6.5" up front and the 6" in the back with penguin 10mm spacers.
Anyway, I want to run the same size tire on both front and back and I'm trying to decide if I should go 195/55 or 205/55. On the 6.5" wheel, 205/55 should fit well, but I'm worried it might be a bit large for the 6" wheels. I could run 195/55, but the tire is about 2% fast and I want to try to get as much tire as possible in those wheel wells. I will be using these for daily drivers and occasional (non-competitive) autocross weekends.
So, what would you recommend?
Thanks! :-)
richard_rsp is offline   Reply With Quote
Old 07-21-2012, 02:04 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
205/55's fit OK on 6" wheels, but that size won't fill up the tire as nicely as 6.5".
I have PG spacers myself and 205 will rub on the rear passenger side fender unless you plan on removing the rear seat. Otherwise you may want to get a thinner spacer for the right side, which is something I plan on asking Joel@PG myself at some point. I also added a little camber to minimize the problem, and it got better but it's still not quite there yet.
Last edited by tk-421; 07-21-2012 at 02:20 AM. Reason: fitment "OK" instead of "great"
Old 07-21-2012, 02:17 AM   #3
richard_rsp
Hmmm...thanks for the info. What offset wheels are you running that they rub? Are they the 38mm in your garage?
Old 07-21-2012, 02:19 AM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
+38 offset.
Old 07-21-2012, 02:27 AM   #5
richard_rsp
Ok cool thanks... Hopefully these won't be a problem since they are 45mm... But maybe I can get them to work...
Old 07-21-2012, 02:41 AM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I think you'll be fine. Rubbing is not terrible, but it is annoying. I'm looking to roll the fenders a bit, which should also help, but it's surprisingly difficult to find those around here...
Old 07-21-2012, 11:04 PM   #7
richard_rsp
Well, I decided to go with the 195/55 R15 Firestone Firehawk Wide Oval Indy 500, more because it was what they have in stock since I have a coupon for $100 off in-stock tires over $500. So hopefully I won't have to worry about any scrubbing. I have an appointment tomorrow morning at 9am...
In related performance news: Also installing my TRD springs tomorrow. :)
Old 07-21-2012, 11:10 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I think you made the right choice. Another advantage is that the tires will be a bit lighter as well. Less rolling resistance FTW.
Old 07-22-2012, 11:54 PM   #9
richard_rsp
They look great!
Old 07-23-2012, 02:58 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Nicely done!
Old 07-23-2012, 03:01 PM   #11
enviri
enviri's Avatar
Drives: 2010 Yaris
Man those rims match everything lol. I also own a set with 195/55r15 for strictly winter use
Old 07-23-2012, 08:01 PM   #12
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
a classic wheel. i used to have them on my corolla. i also used to have them for about 30 minutes on my MR2 spyder ;)
Originally Posted by xnamerxx
you nailed it sir.
Old 07-29-2012, 04:27 PM   #13
detroiter
detroiter's Avatar
Looks great!
Don't forget though that the staggered setup on the Mr2 Spyders was only for the 2nd revision of them. The first model year up until the 2002 models, had the same size rims and tires all the way around.
Old 11-22-2012, 10:32 AM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by detroiter View Post
Looks great!
that's not the truth.
you nailed it sir.
Old 11-22-2012, 11:53 AM   #15
enviri
enviri's Avatar
Drives: 2010 Yaris
all mr2 spyders had staggered rims. the first version was just staggered width. Second version had 15" fronts and 16" rears.
Old 11-25-2012, 12:58 PM   #16
detroiter
detroiter's Avatar
Really? Everything I've read on the mr2 spyder forums stated that first gen spyders had 15" rims and same size tires all of the way around. Second gen spyders is when they went 15" fronts and 16" rears with differeing tire widths as well. -shrugs-
Old 11-25-2012, 06:04 PM   #17
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
This should sum it up.
2000-2002:
Front Wheels
Width 15x6
Offset = et45
PCD = 4 x 100
Front Tires = 185/55/15
Rear Wheels
Width 15x6.5
Offset = et45
PCD = 4 x 100
Rear Tires = 205/50/15
2003-2005:
Front Wheels
Width 15x6
Offset = et45
PCD = 4 x 100
Rear Wheels
Width 16x7
Offset = et45
PCD = 4 x 100
Rear Tires = 215/45/16
Old 11-26-2012, 10:46 AM   #18
detroiter
detroiter's Avatar
Wow well I stand corrected, I'm glad to know this. Thanks!
Wheels and Tire package, CHEAP!! kngrsll Tracking, Racing, Auto-X Forum 3 04-01-2010 01:44 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 05:46 PM
Rim and Tire Questions kustom play Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-02-2008 10:32 PM
