Old 09-07-2007, 07:04 PM   #1
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
Replacing License Plate Lights
I've searched and can't find a DIY to remove the license plate lights. I took a look at mine and I'm not quite sure how to do it. I figured I should ask before breaking the panels trying to remove them. Anyone got any advice or a link to a DIY?
OgDogg is offline   Reply With Quote
Old 09-07-2007, 07:29 PM   #2
YarisFan007
YarisFan007's Avatar
Drives: 2007 Toyota Yaris HB
Are you sure you are unable to remove the license plat lights? I replaced mine w/ hyper blue L.E.D. and it was easy...
All you have to do is- first, remove the light cover: This can be done by using a flathead screwdriver w/ tape or tissue on the tip (just to make sure you don't scratch or damage the cover) and inserting the tip in the lever located on the left side and pulling it down. Next, you'll see the bulb installed inside the cover- all you need to do is to turn it counter clockwise to remove it. That's basically it... then of course replace it with the new bulb and put everything back together.
YarisFan007 is offline   Reply With Quote
Old 09-07-2007, 07:58 PM   #3
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Are you referring to the license plate bulbs or lens cover?
If bulbs, check the manual. I referred to the manual when I changed my bulbs.
If lens, let's wait a while for someone to post DIY. I'm also interested...just for stock knowledge.
aca72 is offline   Reply With Quote
Old 09-07-2007, 08:47 PM   #4
refer to my DIY sedan spoiler intall here. you have to open the trunk and take out that carpeting to access the bulbs. really, you just have to be able to open the top portion of the carpeting.
Old 09-07-2007, 09:04 PM   #5
here's a quick DIY...
Old 09-07-2007, 09:05 PM   #6
and the rest of the pics i just took.
Old 09-07-2007, 10:45 PM   #7
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
The toyota manual has all the light removal tutorials there....
Old 09-08-2007, 12:51 AM   #8
heh, for those who don't look there...
Old 09-08-2007, 01:05 PM   #9
OgDogg
Gas Guzzler
OgDogg's Avatar
DIY CHANGING TRUNK LIGHT
THANK YOU SO MUCH! That was extremely easy.
Old 09-08-2007, 10:35 PM   #10
no problem. glad i can help (if you were talking to me, lol).
Old 08-11-2010, 10:19 PM   #11
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
how do you replace it with an LED bulb?
Old 08-11-2010, 10:33 PM   #12
1.5
Form>Function
1.5's Avatar
ok im getting pissed i cant get the bulb out of the housing
Old 08-11-2010, 11:29 PM   #13
RedRide
RedRide's Avatar
You just pull it out.
Old 08-12-2010, 07:42 AM   #14
1.5
Form>Function
1.5's Avatar
^ lol yea trust me ive tried I cant really get a good grip of the bulb so I tried using tweezers and just wound up breaking the bulb and removing it in pieces. But after inserting the new bulbs into the old housings I reinstalled the old housings and now tag lights and tail lights are non functional??? WHAT THE FUCK AM I DOING WRONG!!!
Old 08-20-2010, 11:34 AM   #15
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Did you reverse the polarity of the bulb when you inserted it? I have blue LEDs in my tag lights.
And yeah, all the lights in the Yaris are a huge PITA to remove. To get mine out I put a little strip of rubber around my pliers and used them to remove it. I managed to get all of them out without breaking them that way.
Old 08-22-2010, 08:29 PM   #16
NateDogg
I like the last two pictures, very in-depth
NateDogg is offline   Reply With Quote
Old 12-07-2014, 09:12 AM   #17
atombaum
Cheapskate Joyride
atombaum's Avatar
Drives: 2008 Yaris sedan
Thanks for posting the photos. The left bulb is intermittent on mine. Need to check the connection.
atombaum is offline   Reply With Quote
Old 12-07-2014, 07:23 PM   #18
jcboy
Drives: Sedan 07
most LEDs have polarity. You'll have to reverse installation if they don't work. Otherwise, check the contacts as some china LED adapters don't make contact with the metal in the bulb socket. they tend to get displaced upon pushing them into the socket (the metal "wire" on the upper right in the pic)
Front License Plate Bracket Yaris_Fan Cosmetic Modifications (Exterior/Interior) 11 12-31-2008 10:04 PM
TRDsparks License plate frame; legal? nqd Off-topic / Other Cars / Everything else Discussions 5 07-06-2007 11:17 AM
License Plate jetaimejsc Cosmetic Modifications (Exterior/Interior) 13 05-03-2007 01:59 PM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 01:58 PM
LB: non-destructive Front License Plate mounting Henshin DIY / Maintenance / Service 14 09-03-2006 02:09 PM
