Old 12-24-2014, 12:34 PM   #1
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
New chirping sound
This seems to have started this morning. Rainy day, I was taking off from a stop light and spun the front tires a bit. Constant, high pitched chirping sound but it goes away when I push the clutch in. I sure hope it's nothing expensive, I've been out of a job since July. I have 32,800 mileage on my car.
DebbyM46227 is offline   Reply With Quote
Old 12-24-2014, 12:39 PM   #2
Probably just the serpentine belt needing to be tensioned. Damp conditions can promote belt slippage.
Old 12-24-2014, 12:40 PM   #3
DebbyM46227
If it's the serpentine belt, why would the sound go away when I push the clutch in?
Old 12-24-2014, 12:42 PM   #4
Reducing load on the crank pulley.
Old 12-24-2014, 12:46 PM   #5
DebbyM46227
Thanks, I hope that's all it is :)
Old 12-24-2014, 12:57 PM   #6
For giggles also check around the water pump for leaks. More common than people think, but the water pump can easily go out around your mileage mark.
Old 12-24-2014, 02:32 PM   #7
DebbyM46227
OK, I'll check for those leaks as soon as it stops raining.
Old 12-29-2014, 11:29 AM   #8
smah
Drives: Toyota yaris 99 reg
Hi everyone,
I am hoping to get some really good help from you as i have the aftermarket keyless entry system but not sure how to install it in my Yaris.Any help will be appreciated.Photo of the System kit is attached for reference.
Thanks in advance
smah is offline   Reply With Quote
Old 12-29-2014, 12:04 PM   #9
Originally Posted by smah View Post
Hi everyone,
Thanks in advance
And what exactly is this doing in a thread pertaining to a serpentine belt?
Old 12-29-2014, 02:30 PM   #10
bairjo
Hi everyone,
Thanks in advance
Come on man...Everybody knows you need a OEM belt to do an aftermarket keyless system.
Old 12-29-2014, 03:45 PM   #11
smah
Sorry mate, I am not aware of what is oem. I am a new driver and like to do new things . Any help will be appreciated
Old 12-29-2014, 07:34 PM   #12
bigjmeister
Drives: 2009 Yaris TS
Is this smah trolling or is he (or she) really clueless? Security !
bigjmeister is offline   Reply With Quote
Old 01-07-2015, 12:34 PM   #13
DebbyM46227
http://youtu.be/dBVrS-PBoxI
Now I'm not so sure it's the belt. Here's a video I made; it's making the sound but not as loud as it usually does. My camera didn't do such a good job with the noise. Sometimes it chirps, sometimes it chatters. Some days even though damp, makes no sound.
Also, take a peek at the end of the video by that round rubber thing....is rust in that area common on those brackets? Is the water pump near there?
Old 01-07-2015, 02:11 PM   #14
bronsin
bronsin's Avatar
Yes the wp is driven by the belt which is in close proximity to the rusty round rubber thing (RcubedT)
You apparently live in a state with heavy salt use in winter hence the rust. I wouldn't worry about it but have the front suspension bolt recall done or at least checked.
I have to believe your noise is one of the accessories driven by the belt. Or at least, if it was my car I would remove the belt and see if the noise goes away and further spin and feel the rotation of the accessory pullys. Im thinking water pump.
Old 01-07-2015, 02:13 PM   #15
bronsin
bronsin's Avatar
Likely its the throwout bearing which operates the clutch. Hows your clutch working in general?
Old 01-07-2015, 03:12 PM   #16
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yea, Bronsin is on it. It sounds like the throwout bearing as you discribed.
-Derrick-
Old 01-07-2015, 04:40 PM   #17
DebbyM46227
For 6 months the clutch has been a little sticky on damp days but after driving it a couple miles it feels normal. On non-damp days it feels normal.
Is that throwout bearing part of the drivetrain warranty? I'd check myself but it's 4 degrees out and I'm staying inside.
I was laid off from my job in July and TODAY I finally got a job offer! I start Monday and being on probation for 90 days I want to get my car in good condition but I hope I don't have to pay for the repair myself.
That rusty bolt repair - I had that repaired about a year ago at Toyota right before the recall came out.
PS: I don't ride my clutch, and I don't hold it in at stoplights. I learned a long time ago with my Honda CRX to put it in neutral at lights.
Old 01-08-2015, 07:05 AM   #18
bronsin
bronsin's Avatar
Dont know if clutch is covered. Youll have to call the dealer. Good luck!
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 06:35 PM
chirping sound in the morning or after a long time parked tyrone_yaris DIY / Maintenance / Service 7 04-20-2012 03:06 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 04:11 AM
Chirping, squeeking sound ToTo Performance Modifications 7 04-21-2007 05:29 AM
