![]() ![]() Drives: 07 Yaris Sedan Join Date: Apr 2007
Windows won't un-fog
I'm just curious to see if anyone else is having window fogging issues. I've never had so much trouble with this on my other cars, but the little Yaris just does NOT want to cooperate.
Turn your AC compressor on along with your defroster. The problem is with removing the humidity from the air in your vehicle, which your AC system will do.
Drives: 2009 Yaris liftback Join Date: Nov 2008
and have it on recirculate mode, correct?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
OK - you two need a time-out. Sorry, Chino, but....
1. The AC automatically turns on "when needed" with the defrost aimed at the windscreen. Nothing you can do to stop it - I've tried. 2. Recirculate will not get rid of fog - stick it on "fresh air". 3. Flame on! (probably) |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
I agree with #1 and #2 above.
... I'm driving down the road. Its cold out. My windows are fogged up. I crank the defroster on high. Nothing. I hit the A/C button and within about 5 seconds my windshield is clear.
That happens, oh, every day during the winter. |
Dang! Want to trade? I cannot turn off the AC when defrosting. Says in the handbook that's what it does, IIRC.... Strange.
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
When my windows fog, and I turn it to defrost, the A/C goes on automatically as well. That's how most newer cars are from my experience.
Fog-X works pretty good and also using shving cream on the window and wipe it off...don't knock it until you try it
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t Join Date: Jun 2007
Get your system checked. When my windows are fog up I put it on defrost and it clears up right away.
The secret of life is honesty and fair dealing. If you can fake that, you've got it made. Groucho Marx (1890-1977) |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Turn on the A/C, fan, and defroster. Turn the knob to "defrost" setting. If that doesn't work, then crack the windows a little to let some of the humidity out. Never fails.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Well, I stand corrected (although I'm sitting down)
Following is from the '07 Owners Manual, showing that you DO need to push the button. Dunno where I (mis)understood that it was turned on automatically..... |
Not really here...
Drives: 2008 Blazing Blue S hatchback Join Date: Oct 2008
I just put it to fresh air and click it on to 4 and all the way to heat and the fog goes away in less than a minute.
Liberate Tutemet Ex Infernis. |
#14 | |
My personal experience is the defrost setting will clear the window in seconds with no need to push the A/C button.
#15 |
Check to see that the body plugs are in place and not allowing more moisture in..... feel your carpets to see if they are wet too.
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
#16 |
Here's some pics of my windows after 45 minutes of driving with the defroster set to recirculate, medium heat, and #4. I tried switching to regular heat, instead of defroster and within 60 seconds the windshield started fogging up. And it's THICK when it does fog up.
I've never had a car do this before. |
#17 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I commute over a mountain that sees over 300 inches of precipitation per year and I have never used the a/c or defrost setting. When the windows fog all I do is crack the window and in a few seconds the windshield is clear.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#18 | |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
| rear corner windows fogging | wushumasterku | General Yaris / Vitz Discussion | 14 | 01-23-2006 03:09 PM |
