Old 03-25-2015, 05:11 AM   #1
dinky123!
Drives: 2008 Toyota Yaris
Black piece of plastic on underside of body
As if burned out bulbs aren't enough, now a piece of plastic on the bottom of the car is scraping against the road when I drive the car. I have it "tucked" back, but this will not hold for very long...any ideas?
dinky123! is offline   Reply With Quote
Old 03-25-2015, 06:21 AM   #2
bairjo
well did you get under the car and look ? without any information I would guess you have a screw loose, missing or a broken panel. seeing that you are driving a seven year old car, that would be my guess. it really should not be difficult to figure out if you actually take a look.
Old 03-25-2015, 07:54 AM   #3
dinky123!
black piece of plastic
I think this piece of plastic is part of the undercarriage, but I don't know if it is essential. I don't know if I should try to take it off. Is this just a plastic cover for the bottom or is it more important?
Old 03-25-2015, 08:11 AM   #4
dinky123!
engine under cover
Ok, so the piece is called the "engine under cover". By this description, I would say it is needed/essential. How can I bolt it back on?
Old 03-25-2015, 08:28 AM   #5
It really isn't essential, but if you want to reattach it as is, drilling some extra holes in it and attaching it with cable ties is the easiest way.
Old 03-25-2015, 08:33 AM   #6
dinky123!
Thank you for a straight answer...I will worry about my front and read bulbs first...
Old 03-25-2015, 11:31 AM   #7
tmontague
tmontague's Avatar
It just healpds protect your engine from road crap. Given the amount of salt on the road where I live, I would consider it pretty important. In your case living in SC, maybe not so much. Like Scott said you can use cable ties or get a few plastic plugs from the dealership, if the iriginal hole are still in good shape then just install the plugs through the holes.
White Yaris Wide Body !!!!! clickis Photo-Video-Media Gallery 49 01-27-2012 03:31 PM
I need a body kit LA Yaris California 1 11-06-2009 02:26 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
