Old 03-26-2013, 07:00 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Engine bay buzz at 3k rpm?
I've noticed recently that when I'm coasting to a stop and my RPMs are over 3K, a strange buzzing noise comes from the engine bay when the tach passes 3K. Has anyone else had this happen before? I'm planning on having someone gently rev the engine while I poke my head under the hood to target it, but it may take a while for the weather to cooperate enough to do that.
Old 02-02-2015, 08:24 PM   #2
mattymo
Drives: 09 LB
Having same problem around 4000rpm. Lighter or harder throttle seems to affect it. Anyone diagnosed this one?
Sent from my GT-P5210 using Tapatalk
mattymo is offline   Reply With Quote
Old 02-02-2015, 09:21 PM   #3
Is the AC on when it happens?
Old 02-03-2015, 06:50 AM   #4
mattymo
Drives: 09 LB
Nope. Happens with or without the compressor on just the same. Sounds like buzzing/grinding sound. Almost sounds like a heat shield vibrating. I hope it's a sheet metal resonance, and not an internal engine sound. For me it seems to happen worse at a "medium" throttle position I like to drive at, as the rpms sweep to 4000 or so. If I give it more or less throttle, the noise doesn't seem as intense.
Old 02-03-2015, 07:49 PM   #5
ex-x-fire
There have been complaints about vibrations on some cars I work on, like a ford focus. We find the there's a bad motor mount that sags causing metal to metal contact at certain engine speeds, revving it up make it better or worse.
Old 02-05-2015, 06:19 AM   #6
John Lenin
Drives: 2009 Toyota Yaris 3-Dr HB Auto
My Yaris is a 2009 2-Dr. H/B, auto-tranny and at a stop with trans in "D", holding car with brake, I have an audible "rattle" as engine idles ... have isolated it to the air filter box (front driver's side under hood) ... apparently this is not uncommon ... either filter box itself is loose or the snorkel attached to it ... will attempt a fix in the spring when the weather gets warmer ...
John Lenin is offline   Reply With Quote
Old 02-05-2015, 08:12 AM   #7
bairjo
Always remember, it doesn't matter if you have an Engine bay buzz or San Franciso Bay buzz going on....never drive buzzed...you may find yourself in a situation...
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Post your engine bay pics! eTiMaGo Photo-Video-Media Gallery 145 04-27-2015 09:50 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
