Old 02-22-2015, 01:00 AM   #1
carlb48
Drives: 2007 yaris 2014 rav4
cold auto trans shifting
When starting off cold the trans won't shift at usual speed, but at very high engine revs. Once warmed up it shifts at usual engine speeds. Any thought?
carlb48 is offline   Reply With Quote
Old 02-22-2015, 01:49 AM   #2
The Limo 2
I think this is normal. My 2007 stays in second gear for 2 or 3 blocks then in 3 for about 1/2 km. I think it is to do with warming up the engine quickly to reduce emissions.
The Limo 2 is offline   Reply With Quote
Old 02-22-2015, 07:05 AM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
they are designed to not go into OD until about 20 seconds after cool light goes out. Its an effort to get the engine into normal operating temp.
Old 02-22-2015, 09:38 AM   #4
Do a search on here for "4th gear prohibition" and you will see that it is an intended mode of operation (which can be bypassed). When it is allowed is determined by the temp of both the coolant and the AT Fluid.
Old 02-22-2015, 07:58 PM   #5
carlb48
Thanks guys. Love this little car
Old 02-23-2015, 07:45 PM   #6
Em_
Drives: 2007 Yaris
Car wont shift to 3rd gear below 42c coolant temperature and wont shift to 4th below 55c reading on the scangauge 2 that is also when the cool light turns off 55c they are made loke that
Em_ is offline   Reply With Quote
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 06:04 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
