Old 02-24-2015, 08:55 PM   #1
JHSmith
Drives: 2007 Yaris Sedan
Yellow Fluid Drips
I saw some yellow fluid drips left from my car the other day after a fresh snowfall, any idea what this could be from? My coolant is red, and the brake fluid seems to be all there. The drips were not concentrated to where the car was parked, but followed the car as it drove along the driveway. I guess it could have been engine oil but I changed it months ago and I don't suspect it would still be so yellow (think brake fluid). Anybody else have this problem?
Thanks for your help,
2007 Yaris 4 door sedan, Automatic
JHSmith is offline   Reply With Quote
Old 02-24-2015, 09:42 PM   #2
The other fluid that is yellow when leaked is the oil in the refrigerant for the AC system.
Old 02-25-2015, 12:07 AM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
cat urine
Old 02-25-2015, 12:52 AM   #4
sheekeebut
Minimalist
Drives: 07 silver sedan
^^especially when it's still warm and fresh
sheekeebut is offline   Reply With Quote
Old 02-25-2015, 01:51 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
Wow! I've seen the same thing a month ago when my driveway was still covered in fresh snow.
I guess I should be able to see the leak by following the AC lines if that was the case right?
Old 02-25-2015, 05:25 AM   #6
bairjo
cat urine
Maybe this helps...
https://www.youtube.com/watch?v=eY7ZX6ngOSs
Old 02-25-2015, 06:11 AM   #7
bronsin
bronsin's Avatar
Could be from melting ice/snow.
Old 02-25-2015, 06:29 AM   #8
IllusionX
Cat urine would be a big patch.
I had just 4-5 drips after moving the car away to remove snow.
Old 02-25-2015, 01:02 PM   #9
shepd
Drives: 2007 Yaris 5 door RS
If it is A/C, shine a blacklight at the snow (counterfeit money detector lights work as well). If the stain glows very brightly, your A/C is for certain leaking. I'd suggest disconnecting the wiring to the compressor for the winter. This way when you repair it in the summer you'll only be repairing the leaky part, not the compressor as well.
Old 02-25-2015, 08:13 PM   #10
ex-x-fire
Sometimes the moisture in the exhaust leaks out in weird colors, I've seen them leak a greenish yellow color.
Old 03-04-2015, 08:17 AM   #11
IllusionX
There, saw the drippings today. Here are some pics
Old 03-04-2015, 09:32 AM   #12
By the color I would almost have to say mouse or chipmunk urine. Did you smell it?
Old 03-04-2015, 09:58 AM   #13
I've got exactly the same thing. Mine is definitely not animal related as there are no tracks in the snow. Unless of course something is roosting somewhere in the under body and peeing down. My yellow splotches are much too large to be mouse.
Old 03-04-2015, 11:03 AM   #14
IllusionX
I did not smell it, I'm sick anyways so i am unable to smell anything right now lol.
As WeeYari says, there are not paw prints anywhere, fresh snow this morning.
Can I test the AC system pressure with a tire pressure gauge?
Old 03-04-2015, 11:45 AM   #15
I've shoveled my drips away, but in thinking about where they were, relative to the position of the car when parked, the drips were nowhere near any of the a/c components. More like mid to rearward section of the car, right down the center line.
Old 03-04-2015, 01:46 PM   #16
bronsin
bronsin's Avatar
Do you have Prestone in the radiator?
Old 03-04-2015, 02:23 PM   #17
IllusionX
I'm still using the original pink coolant.
Old 03-04-2015, 03:30 PM   #18
Jason@SportsCar
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Amsopil transmission fluid two thumbs up! Toolaholic DIY / Maintenance / Service 5 09-11-2015 11:35 AM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
