Old 03-20-2015, 11:20 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Strange Whistle Sound at Idle
Bought a 08 yaris base 1.5l last year.
My old belt was replaced like two months ago with a bando, and it worked fine. Last week I replaced the waterpump and coolant because the bearing was bad. I noticed the car had an intermittent whistle/whining sound for a while. I think I've only noticed it once while driving. Today it was driving me crazy and I looked anywhere where there was vacuum hoses, used soapy water, and nothing. I only really notice it on idle. The only possible thing I would think is the alternator bearing. What do you think?
I noticed between the head and the block, some burned oil. I hope it's not the head gasket
xdarkxfirex is offline   Reply With Quote
Old 03-21-2015, 07:52 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Um, soapy water is not how you find a VACUUM leak. That's how you find PRESSURE leaks. You need to use starter fluid, or propane. As you spray each connection listen for the RPMs to rise. You can use a propane torch too. Just open the gas and put the tip around each joint. Make sure you're outside.
Old 03-21-2015, 08:01 AM   #3
nortonfb
Drives: 2007
You can use WD40. Propane doesn't sound safe if you have a spark some
where that is exposed. I know it's not likely but I have dealt with gas issues.
Also went to HVAC class and saw people without eyebrows.
Norton
nortonfb is offline   Reply With Quote
Old 03-21-2015, 08:07 AM   #4
Bluevitz-rs
Propane is an actual method used by mechanics.
diy, problem, sound, whine, yaris
Strange creaking sound whenever applying brakes at stop position. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-04-2015 04:51 PM
1.33 engine strange tapping on idle dobrik Third Gen Yaris General Discussion 7 10-31-2014 07:26 AM
Strange sound during ignition mikastefh General Yaris / Vitz Discussion 0 06-13-2010 03:58 AM
strange sound when i begin to accellerate? davembfan General Yaris / Vitz Discussion 11 06-06-2007 03:31 PM
