Old 06-19-2015, 02:58 PM   #1
2009Toyotoad
Drives: 2009 Yaris 3dr
Tools needed for MTM fifth gear R&R?
I'm getting ready to change my fifth gear (drive and driven) to a slightly higher ratio. .725 from.815. Its just occurred to me that I may not have the correct tool for the job. I believe that the drive gear with the split bearing set can be removed using a harmonic balancer puller, on the syncro set. The re-install with the replacement 41 tooth 5th gear, I would install the syncro set after the gear using a 12MM 1.75 bolt, a big washer, and a 1 & 1/2" socket to press the syncro set back in place.
It is the "driven" shaft that I'm confused as to what tool is needed. I assume a threaded puller is needed, but I have no idea what Part number or brand to look for. Also confused as to whether the needle bearing need to be removed for the 29 tooth 5th(driven shaft) gear swap.
I hope that all make sense and someone can help me out
2009Toyotoad is offline   Reply With Quote
My Car Shakes Noticebly when I Put The Gear into Reverse When The Car Is on a Slope Meteorite2 DIY / Maintenance / Service 3 11-14-2014 06:56 AM
Which hand tools needed to replace shocks/struts? detroiter DIY / Maintenance / Service 9 04-24-2014 12:25 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 02:30 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
