Old 06-30-2015, 08:35 AM   #1
BillYar
Drives: 2007 Yaris
Unhappy 2007 Yaris Hatchback overheated
My Yaris overheated and died on the road. The belt for the AC, alternator, and crankshaft broke. Had it towed back to my house. Put on a new belt and changed the spark plugs, added coolant to the reservoir until it filled the overfill tank to max. It won't start. It turns over, the crankshaft pulley, AC, are all turning. Any ideas? I hope I didn't fry it. I had an overheat idiot light go on but it went off, I kept driving. Guess I'm the idiot. I've read posts here for starting problems and they say to change out the crankshaft position sensor. Any other thoughts? Thanks
BillYar is offline   Reply With Quote
Old 06-30-2015, 08:42 AM   #2
tmontague
tmontague's Avatar
Is it cranking? I'd run a compression test, it's possible that the head is warped and/or the head gasket is toast and you aren't getting enough compression.
That being said, it would likely still start and you'd have problems come up afterwards. A bad cps will cause a no start. A mechanic w/ a good computer can diagnose a bad cps by seeing if their diagnostic computer is giving rpm readings while the car is cranking. I though that was my issue a while back until it ended up being a bad ground on the ignition loom
Old 06-30-2015, 09:46 AM   #3
BillYar
Drives: 2007 Yaris
Thanks! I've ordered a CPS. Will try that. Maybe I'll get lucky. Didn't want to pay to have it towed to a mechanic.
2007 Yaris hatchback remotebuttons stearing wheel torwith In Car Entertainment + Electronics (audio / video / alarm) 2 06-30-2010 12:58 PM
