Old 01-08-2016, 01:04 PM   #1
juicyjosh
juicyjosh's Avatar
Drives: 2012 Yaris SE MT
Talking Build: Sound Quality In-Cabin Dual 10” Woofer Enclosure (Lots of PICS!)
Greetings Yaris Owners,
This build has the usual goals:
Sound Quality: Tight, accurate bass that would sound good regardless of whether it's hip hop, EDM, vocals or orchestra music, and anything else
No rattles
Bass energy focussed on the two front passengers
Kick in the back
Easy to move around
System flexibility/No compromise with regards to space
Stealth to avoid attracting unwanted attention
Hopefully sharing this build with the Yarisworld may spark some ideas for others for their own builds.
Positive constructive comments are welcome
Calculations and planning:
juicyjosh is offline   Reply With Quote
Old 01-08-2016, 06:46 PM   #2
juicyjosh
juicyjosh's Avatar
Marking cutouts:
Cutting the panels:
Enclosure panels unassembled:
Leftover MDF:
Old 01-08-2016, 07:06 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
is this going in a HB or Sedan?
Old 01-09-2016, 03:45 PM   #4
mr_miles
Drives: 2013 Yaris
All I care about is that rotor in the first picture. BRAP BRAP BRAP. I miss my RX7....
Old 01-10-2016, 09:36 AM   #5
juicyjosh
juicyjosh's Avatar
This:
mr_miles,
That's the dented rotor from my first blown engine.
Yeah, I miss it too.
aaand... the 17.4 lbs. of boost on a new engine with new Efini turbos
Built a stealth system in the RX-7, too
We're back on topic in the next post
Old 01-10-2016, 09:59 AM   #6
juicyjosh
juicyjosh's Avatar
Designing rubber seals to prevent air leaks around the woofer baskets:
10" woofer with seals:
Woofer next to iPhone 4S, and no, I just don't feel like upgrading yet
10" woofer with seal/gasket in place:
Old 01-10-2016, 03:20 PM   #7
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
I am so loving this so far. I have an 8" sub in a prefab box which was made for 2 subs that takes up my whole boot. I'm also in the process of making a stealth setup that's gonna look OEM. May even upgrade the 8" kicker for a 10" while I'm busy to get the best of both worlds :P \m/
MedMantle is offline   Reply With Quote
Old 01-10-2016, 03:41 PM   #8
1nz revolution
Drives: 1nzfe
A little Focal might sound better.
1nz revolution is offline   Reply With Quote
Old 01-10-2016, 04:04 PM   #9
MedMantle
MedMantle's Avatar
Hot stuff! I reckon I wanna see your build complete though for some inspiration as I am a total novice when it comes to woodwork etc.
Old 01-10-2016, 06:36 PM   #10
juicyjosh
juicyjosh's Avatar
1nz revolution,
I agree. That's why I bought a a set of open-boxed Focal 3-way components for the 2003 MR-S.
For subs, however, I've really been impressed with SoundQubed for their ultra-rigid lightweight cone, serious suspension, spring-loaded terminals, insane voice coil and completely exceptional quality.
This HDS208 dual 2-ohm 8" woofer is rated at 600 RMS, but it easily handles closer to 1000 off a Pioneer D-class without bottoming out.
Typical box-building materials. Maybe should have posted this earlier
Ported enclosure mockup (for the 8" sub for the MR-S). Flush-mounted woofer, dual ports (for aesthetic symmetry) and rounded panels for improved efficiency, port aerodynamics and reduced port noise:
Ported enclosure construction. Notice the rounded port channels, pilot-drilled screw holes and straight-through 12-gauge OFC wires for the dual voice coils.
My dremel broke, and I didn't want to spend $40 to buy a new one so all rounded panels were actually done by hand.
Open-box purchase for $360 on the Focal 3-ways
Removed the cheap soft rubber dust caps from the Focal 6-3/4 woofers to be replaced with homemade polypropylene caps:
MedMantle,
Thanks! It just comes from creativity, experience and doing it right the first time, even if it means your project might take a little longer.
Old 01-10-2016, 06:40 PM   #11
1nz revolution
Drives: 1nzfe
A little Audison will brighten it up.
Old 05-04-2016, 01:48 AM   #12
09GLH
Drives: 2009 Yaris 5 door
Updates?
09GLH is offline   Reply With Quote
Old 07-04-2016, 12:28 AM   #13
juicyjosh
juicyjosh's Avatar
http://www.yarisworld.com/forums/sho...d=1#post783291
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
