Old 10-04-2015, 10:03 AM   #1
basit701
Drives: Toyota Vitz (Yaris)
Question Bad Alternator or Battery??
Hello Guys! I own a Toyota Vitz (Yaris) 1KR-FE (CVT). From past few days i am facing problems like dimming lights, vibration when AC or headlights turn on. To diagnose this i checked my battery(approx 2 year old) voltage and DMM was showing about 12.2V. I replaced the battery with new AC Delco sealed maintenance free battery. After changing the battery i am facing these issues.
The engine would crank in the morning and if i turn off and crank again. It would start. But if i drive like 5 6 KM with AC on and turn off the car and start again. The car would take a heavy start like the battery is dead. So i checked the voltage of battery at different instants and these are the results:
Voltage when engine off: 13.08V
Voltage when engine runs after cranking: 13.67V
Voltage after 2 3 minutes of emgine running : 13.34V
Increasing RPM to 2000~2500 voltage after 4 5 minutes of engine running: 13.7V
Turning AC and headlights on @ idle:13.15V and @2000~2500 rpm: 13.28V
I am just confused is the alternator weak or battery is bad(AC Delco is a reputed brand and also the hydrometer on the battery is green which means OK).
Any suggestions???
basit701 is offline   Reply With Quote
Old 10-04-2015, 10:25 AM   #2
It looks like your new battery and alternator are fine. If it is a second generation Vitz (2005-2011), then the problem may be that you need to clean the throttle body. When you disconnect the battery the ECM loses its short term data and if there are deposits of carbon in the throttle body, then the idle gets off a bit, making the car run a bit rough when starting.
Old 10-04-2015, 11:02 AM   #3
basit701
Yes its a Second Generation Vitz. But the thing concerning me is that after driving for like 5 6 KM with AC on and then starting again, why the car take a heavy start?
Old 10-04-2015, 11:48 AM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
second this , carb build up and after battery change it resets the throttle body plate and makes the car run ruff . This is a problem i find with all by-wire throttles . Clean Your throttle body but with key on and gas pedal pushed in to open it do not move it by hand or you will get and engine code.
Old 10-04-2015, 01:47 PM   #5
basit701
Clean with what? Carburetor/Injector cleaner? Or clean cloth?
Old 10-04-2015, 02:52 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
both and an old tooth brush so u can get inside little better.
Old 10-07-2015, 08:36 AM   #7
basit701
Got the throttle body cleaned. Problem is still there. I think startor motor is faulty??
Old 10-07-2015, 06:32 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Starter motor has nothing to do with drivibility it only starts your engine.
Sent from my HTC One_M8 using Tapatalk
Old 10-09-2015, 08:59 AM   #9
basit701
CT Scott i one thing more i have observed. When i start tha car the voltage at battery terminals is 13.89 or 14 Volts. However when the engine is hot (to temp that fan triggers) the voltage at terminals is 13.25 Volts and when i turn off the engine the battery voltage is 13.02. Now 13.25-13.02 = 0.23 Volt. Isn't its less. Same problem has been observed when alternator was temporarily replaced.
Old 10-09-2015, 07:14 PM   #10
Those voltages are OK.
Old 10-09-2015, 08:00 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Think someone has OCD
Old 10-09-2015, 11:17 PM   #12
IllusionX
Drives: 07 Yaris Sedan Aero
I read this thread again. You may be right.
My Yaris doesn't start the same when the car is warm vs when it sat over night.
The Yaris should start even at 11v... It is very unlikely the .25v difference is going to cause issues.
Sent from my A0001 using Tapatalk
Old 10-10-2015, 06:29 AM   #13
basit701
okay Guys the problem has been solved. The culprit was Starter Motor. Its bushes were worn and the armature was not intact between the bushes. Changed the bushes and its YOOOOO
Old 10-10-2015, 07:42 PM   #14
bairjo
Believe it or not I almost suggested that but was not that confident in responding that. Saw that same thing I read on a forum trying to troubleshoot my sister n laws chevy venture...for another issue. glad you nailed it and responded with what you found for the rest of us.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Have you had problems with your coils going bad? grampi DIY / Maintenance / Service 10 09-11-2014 08:54 AM
07 yaris bad alternator Yaris_guy DIY / Maintenance / Service 24 06-29-2011 11:47 AM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
