Old 10-11-2006, 01:54 AM   #1
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Drives: White Yaris Liftback 2 Dr. AT
Power upgrade (pictures).
Well, I am half way through the process, and I have to tell you that it gets simpler and simpler as the minutes past by. At the beginning it looks scary to see 1000 parts and wires and not have a clue what they are for, but once you remove the door panel you get the idea and the process gets simplified. I don't plan to do a tutorial(yet), but I wanted to provide some pictures so you guys get an idea of the location I chose for the brackets, door lock actuator and window regulator, ah! and a view of the switches once installed, the whole thing looks stock and works like a charm.
FYI, I used the Colibri power window kit and the MES door lock kit, both from www.A1Electric.com
I hope the pictures help!
W.A.S.P is offline   Reply With Quote
Old 10-11-2006, 03:01 AM   #2
twixt
Drives: 07 LB,04&06 ninja 636
Send a message via AIM to twixt
nice install, looks Just like mine! i used standard panasonic actuators though. window motors have been working great, once the door is sealed up its pretty quiet
twixt is offline   Reply With Quote
Old 10-11-2006, 09:33 AM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
very nice, now all you have left is the passanger side
will work for parts
vodkalush is offline   Reply With Quote
Old 10-11-2006, 02:01 PM   #4
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Would you be kind enough to post the kit model numbers?
tomjasz is offline   Reply With Quote
Old 10-11-2006, 02:21 PM   #5
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
NICE!!!!!!!!!!!!
tiksman is offline   Reply With Quote
Old 10-11-2006, 02:28 PM   #6
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
clean.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 10-11-2006, 07:04 PM   #7
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
Niceeee...
The only thing is that orange disc where the crank used to be...
TrancosRt is offline   Reply With Quote
Old 10-11-2006, 07:07 PM   #8
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Hey can I ask how much for the power window?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 10-11-2006, 07:58 PM   #9
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Tom, here's the power window kit: http://www.a1electric.com/Merchant2/...duct_Code=Star
And the power locks: http://www.a1electric.com/Merchant2/...Category_Code=
Old 10-11-2006, 07:59 PM   #10
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
$145 from A1Electric
Old 10-11-2006, 08:01 PM   #11
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Originally Posted by TrancosRt
Niceeee...
The orange thing is just a sticker; it's used in case you have to cut to adapt the covers for the hole. In the case of the Yaris there is only about 3mm all around that has to be removed so the cover goes in.
Old 10-11-2006, 10:37 PM   #12
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Hey lookin fresh. Great job
i noticed that you installed some Sat6 Spacers for your speakers. I was just wondering what Screw size did you use???
Old 10-11-2006, 10:44 PM   #13
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Thanks Hasher!.. I used the screws provided with the Sony speakers. After the pictures I took them off because I needed to route the cables from the power locks and windows trough the boot right behind them and decided that didn' want screws anymore, so I enden up riveting the spacers to the door, just like the stock assembly. You can use up to a 5 X 30mm screw for those holes though!
Old 10-16-2006, 03:30 AM   #14
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Can you put the manual handle back on??? That'd be tight, have the manual handle roll it self up, lmao.
pennystocks is offline   Reply With Quote
Old 10-16-2006, 05:49 PM   #15
jbll
Drives: Yaris HB 2007
Where did you get your electricity for the power window?
Cheer!
jbll is offline   Reply With Quote
Old 10-16-2006, 06:28 PM   #16
vst
Drives: 2010 Yaris Sedan x 2
How did you get those power switches? Did they come with the kits? How did you install those?
Also, do you think this kit would work on my Yaris Sedan: http://cgi.ebay.com/ws/eBayISAPI.dll...category=50552
vst is offline   Reply With Quote
Old 10-17-2006, 12:08 AM   #17
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
That would be a little dangerous!... No, but the kit suplies an "emergency" window handle that can be used if anything breaks.
Old 10-17-2006, 12:10 AM   #18
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Cheer!
Right above the fuse box. You have to test which wires are powered by the ignition being in the on position though.
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
The power upgrade thread ChinoCharles DIY / Maintenance / Service 19 09-27-2006 03:14 PM
