Old 02-04-2012, 04:25 PM   #1
Crazy Butcher
Drives: Yaris 2008
Installing New Headunit
So as the title says, i tried to install a new single din headunit in my 2008 yaris.The HU is a sony xplod cdx Gt200, it was easy to install, But once i turn it on i cant control the volume or any setting. I cannot change source to aux or fm radio. All i can do is eject the cd or listen to it at high volume.
There is where my problem started.So i reinstalled the stock toyota headunit back until i find what the problem is.
Can somebody help me out with this?
Crazy Butcher is offline   Reply With Quote
Old 02-04-2012, 04:30 PM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
If it has a Detachable faceplate are you sure it was installed correctly ?
Old 02-04-2012, 04:47 PM   #3
Crazy Butcher
Drives: Yaris 2008
S7: Yes it has a detachable faceplate, i took it off, put it back on it and so on like twice. :( i thought it was the problem but it would eject the cd anyway.
Old 02-04-2012, 05:24 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Is this the first time you've installed a Head Unit or do you have basic knowledge and experience ?
I would power on the unit outside of the vehicle. Idk if you have a 12V battery lying around or even to your car battery just don't leave it hooked to the car for very long.
Where did you buy the unit ? If it's at an audio shop maybe they can help you out and run it to there power inverter and get the thing powered up.
Once powered on you can see if you can move the volume up and down and tap on the source button to see if it toggles through the options. Of course you will have no sound but you can trouble shoot the way you have your harness wired after that. If not then they sold you a faulty deck.
Old 02-04-2012, 05:31 PM   #5
Crazy Butcher
Drives: Yaris 2008
i had this Headunit it the previous car i had but it wasnt me that installed it, and i kept it once i got rid of the car. as long as experience goes with HU, i swapped the sony for a clarion and then i left the clarion in the previous car.
I bought myself a e2 connector wiring harness for yaris 07+ could that be the source of problem?
And to connect the headunit out of the car to the batt what do i need only the 12volt constent,12volt acc and ground?
Old 02-04-2012, 05:39 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Scosche is okay. If i was going to trouble shoot this i'd grab my Yellow and Red wire from the Deck wiring and put them to the Positive side of the battery. Grab the black wire from the Deck wiring and connect it to the ground - terminal of battery. You cd player will power on at this point.
Toggle through the options. And make sure the volume goes up and down. And toggle through the source features.
Be Very careful .
Make sure no other wires are exposed
Old 02-04-2012, 06:05 PM   #7
Crazy Butcher
Drives: Yaris 2008
Well Thanks alot S7V7N, i am going to try this out tomorrow morning before i go to work.
I'll let you know what happens.
Old 02-05-2012, 05:55 PM   #8
Crazy Butcher
Drives: Yaris 2008
This morning i tried my headunit of the battery and its exactly the same,I got power but no volume or any setting/source.
I guess its time to look for a new one?
Old 02-05-2012, 06:44 PM   #9
_S7V7N_
_S7V7N_'s Avatar
Visually inspect the back of the stereo where the harness connects and make sure all the contacts are clear and nothing is bent. Check your wire harness again if anything disconnect all the wires from the scosche harness then retry the test.
After that RIP stereo.
Sorry wish it woulda worked.
Old 02-05-2012, 07:47 PM   #10
Crazy Butcher
Drives: Yaris 2008
Thanks again for your help! i am going to shop for a new one maybe tomorrow or the day after. I cant wait to get my system in.
Old 02-05-2012, 08:24 PM   #11
_S7V7N_
_S7V7N_'s Avatar
What's your budget ?
Old 02-06-2012, 09:24 AM   #12
Crazy Butcher
Drives: Yaris 2008
I put about 150 for the new headunit. At the moment ive been looking on canadian tire and best buy.I dont really mather if its not the biggest baddest HU for 150, i just want something that will be clean. I saw one id like at 129.99, ill wait a couple of days maybe it will go on sale like they usually do.
Old 02-06-2012, 12:19 PM   #13
_S7V7N_
_S7V7N_'s Avatar
I picked up this Kenwood Last year for 150 bucks but it seems to have been Discontinued.
Old 02-06-2012, 01:39 PM   #14
Crazy Butcher
Drives: Yaris 2008
I Just bought a Sony CDX-GT56UI,it was 119.98+tx so i got it for 137,67. I installed it and it works pretty good.I got volume, setting and all im supposed to have lol. I guess the old sony xplod i had before just broke on me, well its not that bad, it lasted me more than 2 years, i hope the new one will last more than 2 years even though!
FS: NIB Ecometer & Used Phase Linear UV8 DVD Headunit kuyachris84 Items for Sale by private party 2 09-04-2010 06:04 PM
help installing new headunit with navigation duck In Car Entertainment + Electronics (audio / video / alarm) 6 07-25-2007 04:30 PM
