Old 12-26-2010, 10:18 PM   #1
dwoodpub
Drives: 2005 Yaris Hatchback
2005 Yaris noise in engine area
My 2005 Yaris has been making a particular noise. It started doing it just once in a while at around 25,000 miles and gradually got more frequent. I now have around 73,000 miles on it. The noise sounds like the bearings are going bad in the pully wheel on either the generator or one of the other ones. It does it at all speeds. When it does it and if I let off the gas it stops. As soon as I give it gas again the noise starts.
dwoodpub is offline   Reply With Quote
Old 12-26-2010, 10:30 PM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
One the alternator not generator, whens the last time you greased the pulleys? And check if the belt has tension if so tighten her up it could be that too.
Old 12-27-2010, 01:40 AM   #3
swidd
Drives: Yaris HB
How do you 'grease pulleys'? Should I put grease on the belt?
Old 12-27-2010, 02:30 AM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Not on the belt, but when you look at the pulley itself and it has a screw holding it inplace not grease my bad with some WD40, I was in a rush my bad
Old 12-27-2010, 06:26 PM   #5
dwoodpub
My third "sorry". I posted it as a 2005 Yaris. It is a 2007. My Tacoma is a 2005. Thanks for all the replies so far.
Old 12-27-2010, 06:41 PM   #6
big lo
big lo's Avatar
Drives: 2007 VIOS
yeah you had me their, a 2005 yaris lmao
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
