Old 11-17-2015, 09:24 PM   #1
M4One
Dropped battdry hook inside engine bay
I was changing out the battery and the hook that secures the battery dropped inside the engine bay. I looked and couldn't see where it dropped to. How worried so I be about it rattling around if I can't find it? Would I be able to go to auto parts store pick it up or do I need to go to the dealership? What about driving around without the end hook temporary?
M4One is offline   Reply With Quote
Old 11-17-2015, 09:35 PM   #2
It is a Toyota specific part. My biggest concern would be driving over it and having it poke into a tire. Check on top of the tranny. If you remove the battery and the battery pan you should be able to find it.
Old 11-17-2015, 10:01 PM   #3
M4One
I still cannot find it after removing the battery and the pan. It's weird because there almost seems like a perfect spot where it could have dropped through to the ground, yet I can't find it, unless it rolled off somewhere l I can't find it. I even moved my car hoping it might drop out.
What about the driving around without the battdry being secured. Safe?
Old 11-17-2015, 10:07 PM   #4
No - I would definitely secure it in some way. You may be able to purchase an aftermarket hold-down that will work.
Old 11-18-2015, 01:47 AM   #5
sex
sex's Avatar
Drives: 09 5DR
Did you check on top of the plastic panels that go to the bumper?
sex is offline   Reply With Quote
Old 11-18-2015, 02:48 PM   #6
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
I once dropped a fuse down there and literally found it a week later just lying there on the gearbox. The stuff can seriously disappear. Like "sex" said, maybe take off the front bumper and it might just be lying there **
MedMantle is offline   Reply With Quote
Old 11-18-2015, 05:12 PM   #7
M4One
The good news is that you can go into your local auto parts store and pick up a battery hold down kit. I went to Canadian Tire and got the 10" (25 cm) for $6.49 before tax. There's a shorter 8" one, but the 10" is the right size. Each kit comes with 2.
The bad news is I still haven't found the original, though I do think it did fall into the panels underneath the bumper. Not directly behind the bumper, but past it. So, without being able to safely lift up my car, I'm not able to access to where I think it is.
Old 11-19-2015, 07:12 AM   #8
bronsin
bronsin's Avatar
When you go to sell the car before giving the keys to the new owner kick the left front tire. The battery hook will fall out of wherever it is.
Seriously the important thing is to get that battery tied down so it doesn't come loose and cause more problems.
Old 11-19-2015, 08:03 PM   #9
M4One
Yeah, the battery is nice and secured now.
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Dumb Question about air coming from engine bay duendeverde DIY / Maintenance / Service 7 01-01-2015 01:12 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
in cabin or in engine bay gwasabi Performance Modifications 4 01-10-2009 12:15 AM
Engine bay prettification project eTiMaGo Cosmetic Modifications (Exterior/Interior) 14 04-23-2007 05:22 PM
