![]() Drives: 2007 YARIS SEDAN Join Date: Dec 2013
random horn honking while driving. plz help
my 2007 yaris sedan just started to intermittently honk while driving. noticed it occurred more when the weather starts getting warmer and when i adjust the side mirrors and lower the front passenger window.
what could be causing this to happen and how do i fix it? Last edited by drinna28; 01-19-2016 at 05:07 AM. |
It could be broken insulators on the steering pad. There are plastic pieces which isolate the airbag frame from the steering wheel frame. If someone ever punched the steering wheel, the insulators can easily break and will eventually allow the horn to stay on.
And as well all know, punching steering wheels can definitely happen, amirite!
Guys? |
would replacing the spring cable fix that issue? the mechanic had told me that was what's wrong
how would i fix that? lol. I've never punched my steering wheel
If your spiral cable has not been replaced for the recall it could indeed be that. For the other issue the solution is unfortunately to replace the airbag, as you can't buy the plastic spacers to replace them separately.
thank you for all your help :)
![]() Drives: T1 Join Date: May 2015
i had a problem where my horn was not working due my steering wheel being slightly bent and therefor could not reach the contact points when pressed in. I would first take the steering wheel cover off to see if it solves your problem. Also check if it happens when the steering wheel is pressed or when it turns
| My horn install... | Goose | DIY / Maintenance / Service | 7 | 01-29-2016 04:10 PM |
| 2nd accident 100% my fault in every way in almost 1.3 million miles of driving | nookandcrannycar | Off-topic / Other Cars / Everything else Discussions | 20 | 01-16-2015 08:44 PM |
| BIG driving lights.... how? | jonismyname | Cosmetic Modifications (Exterior/Interior) | 22 | 09-30-2010 07:54 AM |
| Bad Driving Techniques | Altitude | General Yaris / Vitz Discussion | 10 | 02-10-2009 05:26 PM |
