![]() ![]() Drives: Gray Join Date: Oct 2013
Rad Support bent to sh*t
I have noticed the bottom part of my radiator support has been seriously bent for a few years but I now have a leaking radiator which has forced me to look a little closer under the car. I noticed that the left side of the rad the support is crushed also! Previously I assumed that the bottom piece bending was just from hitting frozen slush in the winter but after a second look that metal is pretty thick. Does anyone else have a bent radiator support due to frozen flush in the winter?
Here is a picture of the bent piece on the left (left side of the car) of the radiator. 20150412_202820.jpg Here is the rad leaking and support under it totally bent. 20150412_202829.jpg btw Any recommendations on a decent radiator that won't leave me broke? |
![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
I don't know if this is possible in the area you live, but there are places that can repair radiators.
Just get a used one an flush it before use.
^this. Shouldn't be very expensive.
you might want to replace that rad support too if you can unbolt it.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
might have been in an accident before? used one from a junkyard that passed a pressure test of would ideally be the least expensive.
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Actually, I just ordered those two pieces for my car. I got side support and the lower rad support for $48 shipped. Mine wasn't bent quite that bad, though. I did hit a snow pile when I bent mine. I didn't even realize I bent anything until I started my engine swap.
The rad support comes apart super easy. One nice thing about this setup. |
| Front seat modification. Increase thigh support. | PetersRedYaris | DIY / Maintenance / Service | 36 | 08-22-2018 01:37 PM |
| Bent brake drums after installing new rims | angrygenerator | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-01-2013 12:09 PM |
| Idea For Japan Relief Support | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 9 | 04-06-2011 09:30 AM |
| new Ontario Race Track - NEEDS YOUR SUPPORT!! | TrackAddict | Canada | 13 | 12-15-2009 07:30 AM |
| Rostra seat heater and lumbar support | sesmith | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-03-2009 08:51 AM |
